Question about Planet Audio 6.2" Automobile Audio/video Gps Navigation System With Bluetooth
Can't click navigation icon - Planet Audio 6.2" Automobile Audio/video Gps Navigation System With Bluetooth
My message envelope will not open
To restore the Envelope icon in the notification area follow these steps:
  1. Start Outlook.
  2. Click the Tools menu, click Options.
  3. On the Preferences Tab, click E-mail Options.
  4. Click Advanced E-mail Options.
  5. Click to select the Show an envelope icon in thenotification area check box.
    Note In Microsoft Outlook 2002, the check box is named Show an envelope icon in thesystem tray.
Outlook 2010
  1. On the File tab, click Options.
  2. Select Mail in the left navigation pane.
  3. In the Message arrival section, click to select the Show an envelope icon in the taskbar check box.
Jun 23, 2014 | HP Pavilion Computers & Internet
Tip
CD/DVD Drive Icon Is Missing
When your CD/DVD icon is missing from the my computer window and your CD/DVD drive is no longer reading any type of media, please follow this simple steps:
Microsoft Windows XP
Click Start, and then click Run. In the Open box, type regedit, and then click OK. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then, delete the upper and lower filters
Microsoft Windows Vista
Click Start, and then click All Programs. Click Accessories, and then click Run. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
on Dec 08, 2009 | Computers & Internet
How to transfer my life studio from one computer to another
Connect the external hard drive to the host computer.
This connection is most commonly made with a USB-style connector.
However, eSATA connectors are becoming more prevalent in the general computing market.
Plug the external hard drive into an electrical power source.
Navigate to the external hard drive listing under the "My Computer" window.
This is opened by double-clicking the "Computer" or "My Computer" desktop icon.
Double-click the external hard drive drive icon listing and navigate to the files to be copied using the provided navigation window.
Right-click the files to be transferred and select the "Copy" heading from the context menu.
Navigate to the destination folder on the host computers hard drive using the same navigation window.
Right-click within the folder and select the "Paste" option.
This begins the process of transferring the files to the computers hard drive.
This process takes several minutes to several hours, depending on the size of the files and the speeds of the hard drives.
A progress bar will appear to keep the user informed of the process completion status.
hope this helps
Jul 16, 2012 | Hitachi LifeStudio HLSDBUB10001BBB 1 TB...
Need help getting my yahoo navigation to work ?????? PLEASE HELP ME THANK YOU
you need to add an exception for yahoo navigation to your firewall. that's why it's not working (at least that's what it sounds like) try and disable your firewall so you can verify that's the problem. if it is, simply go into firewall and click add an exception and navigate to the directory where yahoo navigation is stored.
Jan 31, 2012 | Computers & Internet
When I pull up the gps for directions it says it cannot find program. Please set Gps path in file. What do I do to fix it.
Set GPS Path ..
On your Sylvania GPS go to System Setting > GPS Path .This function is to set GPS path for your navigation. Screen display will show asfollows:
File folders of TF card will be listed on screen. Click a folder to open it. Select GPSSoftware If there are two or more maps from different companies on an TF card, then thisfeature can help you select each of them easily. The way to Select: :In TF card directory,open the file folder to find the map to be used, select navigation software of .exe,(whichhas different names from each different company), then select andclicK 10_3_2011_2_45_46_am.gif icon, a dialogue frame will pop up on screen, as it shown below:
Click the accept icon to accept.
Click X icon on the upper right corner to return to GPS path interface.
Oct 03, 2011 | Sylvania SGPD430 GPS Navigator
How to scan using MP145 canon printer
  1. Place a document face-down on the platen glass.
    (Memo)
    Place a scanning side facing down on the platen glass.
    Align a document with the arrow (the alignment mark), which is at the bottom right corner of the platen glass
  2. Launch MP Navigator.
    1. On the Windows desktop, double-click the 'MP Navigator 2.0' icon.
    2. Alternatively, in the Windows taskbar, click 'Start', click '(All) Programs', 'Canon Utilities', 'MP Navigator 2.0' folder, then 'MP Navigator 2.0' icon.
  3. Click 'Scan Photo/Document'.
    The Scan Photo/Document window will be displayed.
Aug 16, 2011 | Canon PIXMA MP150 All-In-One InkJet...
How do you change the resolution for scanning?
  1. Launch MP Navigator EX.
  2. On the Windows desktop, double-click the 'MP Navigator EX' icon.
  3. Alternatively, in the Windows taskbar, click 'Start', click '(All) Programs', 'Canon Utilities', 'MP Navigator EX' folder, then 'MP Navigator EX' icon.
  4. Click 'Photos/Documents (Platen)' on the Scan/Import tab.
  5. When the Scan/Import window is displayed, check Use the scanner driver, then click Open Scanner Driver.
  6. Change the resolution.
    According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
    To set the resolution in Simple Mode:
    (A) Select the 'Simple Mode' tab.
    (B) In Destination drop-down, select the resolution which suits the purpose.
  7. To set the resolution in Advanced Mode:
    (A) Select the 'Advanced Mode' tab.
    (B) In Output Resolution drop-down, select one of the preset resolutions, or enter a number from 25 to 19200 to specify your favorite resolution.
    In either Simple or Advanced Modes, select other settings as required and then click 'Scan' to start scanning
Let me know if you have any other questions. Thanks.
Jan 13, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I need an instructional manual for the Olympus D-395 digital camera.
Hello
You will be able to download the user manual at the link below.
Click HERE to navigate to the download page.
Once you are navigated to the page, scroll down and click on the "GET MANUAL" icon.
Kind regards
Andrea
Jul 27, 2010 | Cameras
Desk top icons not shown
to add easily, navigate to the program that you want an icon on your desktop, right click it and select send to > and choose desktop.
Doc
Sep 09, 2009 | Microsoft Windows Xp Home Edition Sp2...
Left side of touchpad not working
Go to your "Device Manager" (Right click on ‘My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Pointer/Navigator"). If there is some kind of a "Warning" icon superimposed on the "Pointer/Navigator" icon there is your problem!
Uninstall the DRIVERS for THAT DEVICE only.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.").
Or it could be dirt or soda.
Oct 29, 2007 | Compaq Presario V4000 Notebook
Planet Audio 6.2" Automobile Audio/video Gps Navigation System With Bluetooth Logo
42 people viewed this question
Top Planet Audio GPS Experts
Are you a Planet Audio GPS Expert? Answer questions, earn points and help others
