Question about Toshiba 14.0" L745-s4235 Satellite Led Laptop Core I5-2410m 6gb Ram 640gb Hdd
It barely flashes TOSHIBA then goes to a password entry that I don't know
  • 79 Answers
Most probably a password has been setup in BIOS to prevent unauthoirsed use.
You need the password, or you need to reset the BIOS. This is difficult in laptops as the case is hard to get into.
Also generally the battery needs to be removed/replaced in laptops, rather than opening and closing a jumper, as in a desktop pc.
Posted on Apr 05, 2015
Testimonial: "Resetting the password is definantly what I need to do however, i cannot get in to any usable data levels to do so... the removal of the battery (the little round one inside) does not do the trick either... If I knew where to find the jumper thats what I would focus on... but alas that info eludes me also"
Don't know HDD #1/SSD #1USER PASSWORD ON MY TOSHIBA
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Oct 03, 2012 | Toshiba Satellite L455S5980 Notebook
My toshiba l455s5008 has been in lockdown an i forgot the password an dont know how to fix it
Forgot windows password? Don't worry about it, when I forgot the password, i remove the password by the following steps,
Step1: Download and install Windows Password Recovery Tool Professional.Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn aWindows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4: Remove the forgotten Windows password with the burned CD/DVD/USB. Then log on to Windows without a password.
As the above method, you can finishwindows password remover, I think it is helpfull for you.
Aug 20, 2012 | Toshiba Satellite L455S5008 PC Notebook
My Toshiba laptop got wiped and failed to wipe. So when I try to restart it, it asks for a BIOS PASSWORD in a blue box. I've tryed all tricks and don't know. The satelite number is L455-S5009. I...
The BIOS and Supervisor passwords cannot be removed or changed unless you know the existing password(s). If you forget your BIOS or Supervisor password, you will have to have the password removed by a Toshiba Authorized Service Provider
Aug 17, 2011 | Toshiba Satellite L455-S5009 laptop
I havent used my laptop for 3 years. I tried to turn it on and I have forgotten my password.
Any authorized toshiba dealer can remove the password for you (or should be able to) and some will do it for free, but you must take the unit in.
If you cannot find one locally, you can ship the unit to me, and I will remove the password for $25. You must pay shipping.
Jul 28, 2011 | Toshiba Satellite A45-S1202 Notebook
Toshiba laptop hdd1/ssd1 password i don't know
You can try calling Toshiba's laptop support line but they will require proof of ownership. If they can't get it removed then your only option is to get a new hard drive. Reason is because when a hard drive password is put on a hard drive its programmed into the circuitry in the hard drive so if you don't remember the password then you can't get past that screen.
May 28, 2011 | Toshiba Satellite L455-S5975 Series Laptop...
Hi when i turn on my laptop it powers up then screen goes black ,in the top left hand corner it says password there is a horiizontal little line flashing and it wont let me type in the password,please...
Sounds like the BIOS password has been set to prevent unauthorized usage. If you don't know the password, you can't use the computer and it can't be reset except by Toshiba.
May 17, 2010 | Toshiba Satellite Pro L300 Notebook
Bios backdoor for toshiba laptop
System (BIOS) Password Reset
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
Oct 07, 2009 | Toshiba Satellite M55-S3293 Notebook
Toshiba Portege 3500 Win Xp Bios password - How Can I flash bios?
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
After that use the patch
Mar 08, 2009 | Toshiba Portege 3500 Tablet PC
Toshiba 14.0" L745-s4235 Satellite Led Laptop Core I5-2410m 6gb Ram 640gb Hdd Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
