How much water does this model use in both washing and rinsing.
Is it 7.5kg in size?
    Sergeant:
  • 242 Answers
This unit will have a sticker on the rear panel that gives you all the information....If it is missing save time and headaches and just call the dealer for a detailed explanation ...
Posted on Apr 05, 2015
Any suggestions to washing machine which works with irregular water supply?
all models have a water level sensor in them that you set according to the wash load you have
when you turn them on the water flows until the level set switches off the inlet tap and proceeds to wash
regardless of the water pressures and delivery, the wash will not proceed until the water level setting is reached
the problem that you face is that during the rinse cycle , there may not be enough water available to rinse within the rinse/ spin cycle
Aug 14, 2016 | Indesit Washing Machines
Why does it take so long to wash cloths I have done everything 1 hour and half still washing
Hi Robin,
Many washers have different wash settings and rinses in addition to temperature options and water levels (or load size). The temperatures wont affect the wash times (but hot and warm water washes will cost you more for the expense of making the hot water), so choose whichever you think you need. The water level makes a small impact each time it needs to be filled (wash, rinse, etc.). A warm wash will fill in half the time as either a cold or hot wash - as both hot and cold water are combined to make a "warm" water cycle.
A "Normal" or "Regular" wash without a pre-soak or pre-wash cycle and a single rinse is usually sufficient for *most* laundry needs - especially if you're using dryer sheets. Otherwise, you may find fabric softener is not rinsed out enough to your liking (or not - it's a personal choice).
If your machine offers a "Max Extract" or longer spin setting - it is worth running it to reduce the amount of time they're in the expensive-to-use dryer.
If you need more help - provide your washer brand and model.
Oct 27, 2015 | Washing Machines
I bought a brand new Hotpoint washer, model #HSWP1000M3WW. The water level for super size load during wash seems high enough. But the water level for the rinse is about a third of the super wash level. ...
I would check with the vendor that sold you the unit and see what they have to say or send an email to the Contact Us link on their website and ask. I am guessing no mention of the in your owners manual?
Dec 03, 2014 | Washing Machines
My washer initial had a rinse cycle problem where no rinsing occur after washing, now it spreads to the wash cycle where it is pausing at the this cycle, need urgent advice
The problem is you are not getting cold water fill. (rinse is all cold water fill) Check to see if the inlet screen is plugged by turning valve off that supplies cold to the hose attached to the machine, then removing the hose at the machine and checking the filter inside the water valve where the hose was just removed from. If screen is not blocked, replace water valve.
Nov 20, 2011 | GE Washing Machines
Water level on rinse is to low, on wash cycle the water level is good, I think maybe three quarts of water come in for the rinse cycle, please help. brand new admiral model # ATW4475XQ
this machine has a water level switch for the wash cycle and a switch for the rinse ccycle. remove control panel and take a small screwdriver and rotate the lever on the rinse cycle switch 1 click. (the rinse cycle switch is the one that does not have the knob on it. Unplug the machine before this is done. You will now have a full tub of water for the rinse cycle.
Jul 24, 2011 | Admiral Washing Machines
Washer will go thru the wash but always stops at
ck the cold water is on / ck the water valve . this would stop it in cycle . it can't get rinse water . maybe pc control but unlikley.mm
Dec 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Water will not shut off in washing machine
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
WATER USEAGE
Depending on the age and size of your washer-Front loaders cut water use by nearly 40 percent. A typical top-loading washer uses about 40 gallons of water for each full load. In contrast, a full-size horizontal axis clothes washer uses only 20 to 25 gallons. That means that, by purchasing a horizontal axis model, you could save as much as 7,000 gallons of water per year. You also save all the energy you would have used to heat that water, meaning added savings for you and a big boost for the environment. These appliances also use less energy than conventional washers - approximately 50 percent less, according to the Environmental Protection Agency.
Feb 10, 2009 | Kenmore Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
