SOURCE: we have a kenwood kdw12st3a
To clear the fault you need to remove the two baskets from the dishwasher.
Slide it out from under the worktop and lean it forward to about 45 degrees.
If it is already full of water, turn on the power whilst pushing the programme button, this sets up a pump out program
SOURCE: I HAVE A KENWOOD KDW12ST3A
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
SOURCE: I have a Kenwood KDW12ST3A that intermittently
Hi
E1 means no inlet pressure. Sometimes fault code shows if machine takes too long to fill. Kindly check for blockage in inlet pipe. Also check if water inlet is not filling and check if the water outlet valve is opening and there is sufficient water pressure.
Please do rate the solution as "FixYa" and revert for any clarifications.
Thanks
Rylee
SOURCE: kenwood dishwasher kdw12st3a user guide
GO TO PARTMASTER http://www.partmaster.co.uk/cgi-bin/home.pl
SCROLL DOWN TO BOTTOM LEFT AND USE INSTRUCTION MANUAL DOWNLOAD
AND ITS FREE.
SOURCE: kenwood KDW12ST3A
E1 indicated long filling time. Perhaps the inlet filter has clogged. Check the inlet pipe and tap(faucet in usa).
