Question about Dryers
I only have 3 prong service available. Unit has a 4 prong plug. Can I just change the cord to use the 3 prong service?
  • Dryers Master
  • 5,323 Answers
YES U CAN AND THERE ARE VIDEOS ON YOUTUBE SHOWING YOU HOW TO, HOWEVER IF UR LIVING IN A NEWER HOME BY LAW IT IS REQUIRED THAT U USE A 4 PRONG UNLESS UR HOUSE HAS 3 PRONG OUTLETS SO U MAY BE OK AFTER ALL AS FAR AS THE LAW IS CONCERNED
Posted on Apr 06, 2015
Changing 4 prong plug to 3 prong plug on a Kenmore ultra fabric care electric dryer, where is the metal strap?
The metal strap connects the neutral to the housing ground connection when using a 3-prong cord. It may have been removed when the 4-prong cord was installed.
Feb 17, 2017 | Kenmore Dryers
I have 3 prong service for double 30 power for stove. The unit has a 4 prong plug. Can I just change out the cord, or does it require rewiring the house?
The unit is set up for a dedicated neutral you will need to have the outlet changed to 4 prong with a neutral
Apr 05, 2015 | Kitchen Ranges
Can I change the 220 plug on the stackable unit from a 4 prong back to a three prong.
Yes you can. Green in the middle and red and black to the matching sides coming in from above the block where your connecting the cord
May 07, 2012 | Kenmore 98702 Stacked Washer/Dryer
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
Need to change 4 prong drier plug to fit 3 prong eletric
Purchase a 3 prong dryer cord. It is simpler and safer than changing the wall outlet.
Nov 03, 2009 | Dryers
I am trying to change a 3 prong dryer plug to a 4 prong
You are correct, the green wire is ground. You may be able to connect to the same location as the green wire from the unit.
The white is neutral and the red and black are both 110V (your unit uses 220V).
Here is a link to a picture. I hope it helps:
http://repair2000.com/cord.html
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
3 prong to 4 prong cord
the bare wires are not a good thing when it comes to electric, you should either remove the plug and restrip the wires to fit or consult a pro to do this for you
Mar 06, 2009 | Maytag Neptune MDE6700A Electric Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
I hope this helps you. If you have any questions, please let me know.
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
