Why do i get protected up on minidisc even after i remove protectin tab?
Sometimes 9not always I also get a c13 code error.......reading fault
SOURCE: MDS-JE480 MiniDisc Deck
The problem with the TOC reading and then appearing C13 is a problem with bad electrical contacts.
Remove the connection to the mains outlet, remove the top cover (5screws) and the remove the 2 paper flatcables that connect the main PCB and the disk unit on both sides. Plug them back in and possible your problem is solved.
A better solution is, of coarse, to replace both cables by new ones, as the quality is rather bad, and once disconnected, they should be replaced.
Good luck!!!
1000 soluciones
Posted on Jun 22, 2009
HW_Dude
  • 87 Answers
SOURCE: sony minidisc MDS-JE530 c13 rec error
This could be a solution for your problem, if you get a C13 error it's because of dust on the lens causing TOC read errors. Try blowing out dust using clean compressed air (the kind in the can used for computer maintenance).
Posted on Aug 03, 2009
Obertelli
  • 3006 Answers
SOURCE: Won't record. Often get read error when inserting minidisc.
The head assembly has a read head and a record head (combined into one sub-assembly). Unless you're in a very dusty environment or are a heavy smoker then it's difficult to get dirty heads, it's much more likely that your unit is just suffering an age-related head failure which will progress further to affect disc playback as well. The first sign of a playback error will be the dreaded "TOC error". There is no fix: the units are long discontinued and the heads do not last forever. Spare ones are as rare as fresh **** **** and are not easy to fit. The unit has lasted far longer than it was designed to and is now on the slippery slope to total failure. While you still can, make analogue transfers of any music which you only have on minidisc and prepare to switch to a newer format in the near future. It's a real shame as the sound quality on a good MD unit still blows anything which has followed it (especially the iPlayer) out of the water.
Posted on Apr 21, 2010
Obertelli
  • 3006 Answers
SOURCE: Sony MDS-JE480...Inserting disc..C13 error READ
The c13 error means that the player is unable to read the table of contents (TOC) on discs any more.If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
On the plus side, there are millions of MD units now lying unused as folks have moved on from them and as they're mostly worthless people don't generally bother with trying to sell them. Almost every piece of MD gear I own has come free of charge via my local FreeCycle and Freegle groups. Whatever you do, don't buy a used player from anyone: they're all getting on now and the TOC error is an age-related fault which may occur at any time.
If you wish to see exactly what features other machines have then visit the superb equipment browser at minidisc.org. The site is hosted but n longer maintained though so some information is out of date, but it's still the most comprehensive source of free information about MD available.
Sorry here's probably no hope for your MDS-JE480, but I hope that my reply has given you a practical alternative means of solving your problem.
Posted on Oct 07, 2010
Obertelli
  • 3006 Answers
SOURCE: disc error displaying on je500 and read error c13 on je330 model
The error means that the player is unable to read the table of contents (TOC) on discs any more.If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
Sorry there's probably no hope for your players, but I hope that my reply has given you a practical alternative means of solving your problem.
C-13 read error
You forgot to say if it is a C13 read error or a C13 REC error.
Your owner's manual suggests that it is a problem with a dirty and/or crappy disc. Try a different, cleaner one.
Oct 15, 2012 | Audio Players & Recorders
Ac13 read error
C13 means the player or recorder cannot read the table of contents on the MD you inserted for some reason.
Nov 15, 2011 | Sony Audio Players & Recorders
MINI DISC READ ERROR C13
Your deck can't read the table of contents on the Minidisc for some reason...
Oct 01, 2011 | Sony MDS-JE480 Mini Disc Player
MDS JE520 Disc stuck in unit Toc light on. Previous to this state C13 error flashing.
the C13 is a mechanism error. The TOC means Table of Contents which is the part of the disk that determines the beginning of each track. These units are somewhat delicate and not really DIY repair candidates. Parts are still available for these. Look for either an authorized Sony service center or at least a shop that has worked on these in the past for repair assistance. The loading mechanism may need to be repaired or replaced.
Dan
Feb 03, 2011 | Sony MDS-JE520 Mini Disc Player
Sony MDS-JE480...Inserting disc..C13 error READ CODE, keeps ejecting disc so dont know what to do pls help
Sep 02, 2010 | Sony MDS-JE480 Mini Disc Player
Giving "Read Error C13" but will play Maxell Cleaner Mini Disc. Won't read previously recorded disc from Sony recorder (when it did before)
HELLO
Strange one this! C13 is a protection error, but the machine should play discs that it recorded. It could be that you may have to give the laser lens a good cleaning by using a cotton bud and a little isopropyl alcohol. You will have to remove the cover to do this and when you clean the lens use a gentle circular motion.
Don't soak the cotton bud when you do this but if you do, remove any excess liquid. Leave it for about 5-10 minutes then try the machine again.
If there is no change, then you will have to take it to a service centre in your area.
GOOD LUCK!
Apr 13, 2010 | Sony MDS-JE480 Mini Disc Player
Sale c13 read error
C13 read error means that the player is unable to read the TOC (Table Of Contents) on the minidisc. it has to read this first so that it knows where everything is stored on the minidisc.
TOC errors can be caused by faulty minidiscs, those which have been incorrectly finalised or by a faulty head assembly on the machine.
If possible, try to see if you get the same problem with different brands of minidisc, and also whether minidiscs recorded on other machines work on your player and whether minidiscs recorded on yours work in other players. Report back with what you find as it helps determine whether the player itself is at fault.
In reality though, it's a 9 year old unit and like all optical disc devices, minidisc heads do not last forever. If the head has failed then your only fix is to replace the player as spare parts are no longer in production and existing stocks are almost as rare as fresh dodo doo-doos.
Mar 16, 2010 | Sony MDS-JE470 Mini Disc Player
Sony minidisc MDS-JE530 c13 rec error
Aug 02, 2009 | Sony MDS-JE330 Mini Disc Player
I have a problem, minidisc deck mds je 480
HELLO
C13 is what is called a "Protection Error". This normally happens because the if you look on the bottom edge of the minidisc itself you will see what looks like a plastic strip or tab at the bottom left.
Pull it to the left for it show fully and this will enable you to record onto the disc. Move it right, and this will PREVENT recording from taking place.
If you have the unit connected up by the optical lead and you're trying to record the audio from a DVD unit, the MD deck is probably telling you what you are trying to record is copy protected. I never use the optical lead, just hook it up by good quality interconnects and the recording you get is superb. Both DVD & CD audio!
All The Best! :-)
Jul 23, 2009 | Sony Audio Players & Recorders
Doesn't accept md's
The manual says "C13/Disc Error: The system cannot read the disc information correctly. mEject the MD once, then insert it again."
It seems this error turns up when the system cannot read the disc properly, one reason for which is a dirty/dusty lens. Try a minidisc lens cleaner if you haven't already.
Tom
May 02, 2009 | Sony CMT-MD1 Shelf System
236 people viewed this question
 Grubhead
Grubhead
