Question about Home Security
Please help I bought a wireless out door camera WANSVIEW ip outdoor camera NCM628D02 and can't find SD slot have opened it up the front part of camera and still can't see it .. I'm begging help me
smartr10U
  • 1305 Answers
SOURCE: the SD slot on my digital camera looks wider than an SD card
specs says it's compatible with sd cards and MMC cards..
Posted on Dec 07, 2009
  • 11967 Answers
SOURCE: Computor does not recognize the camera(via usb) or sd slot
Posted on Jun 26, 2010
SOURCE: SD Card
did you ever find a solution?
Posted on Jul 25, 2010
  • 275 Answers
SOURCE: can I upload picture from my pc onto mt C182
Can you take out the card from the camera and put it into your computer and do it that way?
Posted on Dec 16, 2010
  • 6702 Answers
SOURCE: PLEASE PLEASE HELP ME I AM BEGGIN u I sent a picture in earlier of the inside of my outside wireless IP SECURITY CAMERA as I cannot find the SD card slot It's not on the camera Its inside its like pic
It is the metal and shiny square on the left, mounted on the blue circuit board. On this picture you have to slide the card in from the left.
Posted on Apr 05, 2015
Outdoor Digital Wireless 2 CCTV camera System 7" LCD monitor DVR Record to SD TF but recorded playback poor what can I do please I am 81
Try recording in a higher quality than standard and see 2hatcthe results are.some of those are low resolution cameras and you won't get a wonderful image out of them.
Jun 28, 2015 | OUTDOOR Home Security
Apr 05, 2015 | Home Security
Wansview IP camera not connecting
Did you install the drivers for the camera? Check your cables and also try your camera on the TV or other devices.
Jan 05, 2014 | Computers & Internet
Wansview NCH-532MW login fail
if u r running windows 7 pos compatibility issue. i had win 7 64 bit and got the same issue. tried xp on virtual machine works fine
Jan 30, 2013 | Diagonal Wansview Nch-532Mw Wireless/Wired...
Where to insert sd card polaroid a515 digitgal camera
Open the battery door, located on the underside of the camera (use your thumb to slide the door outwards). Install the SD card into the slot located next to the battery bay. Close the battery door.
Apr 04, 2011 | Polaroid i830 Digital Camera
Need to know how and where to insert sd card
There are usually 2 places that an sd-card can be inserted in a digital camera - Inside near the battery under the door, or a separate flap on the bottom of the camera labeled SD.
  • If there isn't a slot specifically for an SD-card on the bottom of your camera, open the battery door.
Try and locate a very thin rectangular ****. Once you have found the slot, take your sd card and push it inside the slot until you hear a click, that means it's securely in place.
Apr 04, 2011 | Polaroid A515 Digital Camera
My Dad, 91years old, received a Kodak Easyshare model z1285 from a friend for christmas. no manual. He lives 400 miles away and called to ask if I knew where the SD card goes. Since I can't see the camera...
The door to access the SD card slot is on end of the camera which is closest to the round knob on the top of the camera.
If you turn the camera on end and look at the door, it has small groove in it that is about an inch long. Holding your camera in your left hand with the lens toward your palm, take your finger nail of your right fore finger and slide the door toward the back of the camera.
The door will swing open, revealing the slot for the SD card. When you get the camera, there may be a "dummy" plastic SD card in the slot. Release it by gently pressing the edge of the SD card and quickly releasing it. The card should pop up about a half inch and you can grab it with your fingers and pull it out.
Replace it with a fresh SD card, making certain that it is oriented with the label facing the back of the camera and the contacts facing the front of the camera. Gently push it into the slot until it seats. Don't force it. The card should go in with a little resistance, but does not require a lot of force to seat. Pressing it too hard will cause it to pop back out again.
If it doesn't seat properly, the card may be flipped the wrong way. The card should go into the slot contacts edge first, contacts facing the front of the camera and the label facing the back of the camera.
I hope this helps,
Art
Jan 01, 2011 | Kodak EasyShare Z12851 Digital Camera
I don't have a cd slot how can i view my pictures without the cd
Did you mean card reader slot (built-in type at your PC's front)??
If yes,the solution is simple...find an external card reader that accepts card(s) used by your camera.80% of today's camera use SD Card or its variants.The SD card reader is a cheapo thing that could be bought from every computer store in the world.
Jul 24, 2010 | Innovage Mini-Digital Camera
It says "sd door open"
SD Door open means that the SD card Slot door is not clsed properly. open the slot remove the card & re insert the card & close the door.
May 08, 2010 | BenQ DC E53 Digital Camera
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
Home Security Logo
104 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
