Question about Sewing Machines
I cannot get my Wilcom program to connect to my embroidery machine. All ports,bauds, protocol were put in.
    Master:
  • Sewing Machines Master
  • 470 Answers
I would contact their Support people:
Contact Wilcom
Posted on Apr 05, 2015
How can I send designs from my PC to my Toyota 830 embroidery machine when my Pantograms software/hardware is no longer working?
Some of the Pantograms software programs require a USB dongle connected to the computer. However, the driver for this dongle has to be installed before you install the software or connect the dongle. I suspect you may not have installed the driver or the dongle is missing.
Assuming that the dongle is connected:
Close your embroidery software program and all of the Pantograms software, including the Network C software, on your computer and remove the USB device. Put the software install CD into your machine's optical drive. (If your new machine doesn't have an optical drive, get a USB optical drive or copy the files from the CD to a 1GB+ USB flash drive at another computer with an optical drive.) If Windows XP starts the autorun routine for the CD, click Exit. Then double-left click on My Computer to launch File Explorer. Go to the CD drive (or USB drive if you used the work-around) and double-click on it. Open the Rainbow Drivers folder and then open the XP folder. Double click on the program: setup.exe . Choose Complete install as the program executes. Then close File Explorer when the install is done. Now insert the USB dongle and follow the on-screen message about New Hardware found to install the Rainbow driver from C: .
If you do not see the New Hardware found message, try putting the dongle into a different USB port. (Make sure to avoid USB hubs - they can add to USB device issues.) If the dongle doesn't work at any port, you may need to use a different method. There is a flash reader available for connecting a USB flash drive to the Toyota 830 here: http://www.plrelectronics.com/lab/usb_reader.php . (Scroll down to the Toyota machine section. This isn't cheap but it is cheaper than some of the newer embroidery software packages.)
I hope this helps.
Oct 26, 2014 | Sewing Machines
When downloading a design on my computer what format do I use
That depends on your machine and/or what software you have. Brother embroidery machines use PED. If you have editing software other than Brother, like Sew What Pro, Wilcom...you can use most formats and convert to the appropriate one for your machine.
Sep 04, 2014 | Sewing Machines
Help I am missing one of the original software disks the the embroidery and digitizing program.
The software has been upgraded many times and now uses a USB port. Which version of software and which disc are you missing? I may be able to help.
Nov 19, 2013 | Husqvarna Rose
Does Janome have software available for a MacBook Pro and Memory Craft 10000 Digitizer?
No:
I just got an email this morning from Wilcom that suggested that they are working on something for a Mac. "Wilcom Elements 3" If another expense for new software isn't an option I would consider getting a secondary computer.... a PC.
If you can run PC at all... go to a pawn shop and buy one specifically for your embroidery machine. A couple years ago I got a 1 year old PC for my husband for $60 at a local pawn shop. I needed to clean out the former owner's personal pictures and tax info... but I was able to access and restore the factory settings and it runs like new.
Feb 26, 2013 | Sewing Machines
Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
Jun 10, 2012 | Brother PE770 Computerized Sewing Machine
I have a Husqvarna 1+, how can I connect my laptop to it to download embroidery designs?
Sorry,... there is not a connection to allow you to do that. However there is a Reader/Writer unit that you can plug into a USB port on your computer and write a design to the card that comes with the reader/writer and then put the card in the machine to embroidery a downloaded design.
Doug
Aug 05, 2010 | Husqvarna Designer I
Programing
program-controlled sewing or embroidery machine comprising a stitch-forming device (2), an integrated microcomputer (4), at least one memory (16, 17) and at least one data interface (5), as well as a keyboard (12) and a display (11) for entering and monitoring or checking values for program control. To retrieve sewing or embroidery pattern data from a remote computer (mailbox) in a simple manner, the data interface (5) of the sewing or embroidery machine (1) is able to be connected directly to the mailbox (10) of a central computer (9) via a data transmission connection (7) via a corresponding modem (6), and the structural units which are necessary for communication with the mailbox (10), such as display (11), keyboard (12) and memory (16, 17) are disposed in the sewing or embroidery machine (1) itself, with the functional processes necessary for communication with the mailbox (10) being able to be controlled and monitored by the microcomputer (4) necessary for controlling the program of the sewing or embroidery machine. The invention further relates to a method of operating program-controlled sewing or embroidery machines.
Mar 17, 2008 | Elna Quilter's Dream 6003Q
Unable to read original card
I called brother and I had set the hoop size to the wrong demension. I had it set for a 5X7 hoop and my machine uses a 4X4 hoop, It works fine now. Hope this helps you
Jan 27, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
47 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
