USE TO WORK FINE NOW ONLY READS HEARD THERE'S A 1000 READ WRITE MAX IS THIS TRUE & IS THERE A COUNTER SOMEWHERE
  • NOEL
    NOEL Apr 18, 2015
    Hi Leo Laureano, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 5,631 Answers
What "reads only"? Hard disk has no limit to write and there is no "counter" for that. You may have some inconsistency in your hard drive.
Go to CMD: (Start) and run chkdsk C: /F probably it will ask you to restart computer to finish checking. Do it.
Hope this should solve issue
Posted on Apr 21, 2015
When insert game into my 3ds it wont read game
I have the same kind of problem. It does not read my Kingdom Hearts 3D cartridge at all, regardless of any way I tried to make it read it. I heard it may have something to do with regional difference and it's true - the 3DS comes from USA, while the game from Europe. While I have Pokemon Diamond cartridge, which is also from Europe and it reads it just fine. Does it mean the regional difference matters only in case of 3DS cartridges?
If not, how can I solve my problem?
Jun 25, 2012 | Video Game Consoles & Games
How to set GDT-311 Digital Multimeter to x 1000 ohm setting?
The 20K setting is close to what you're looking for. The 200 scale is best to read 0 to 200 ohms, the 2K setting would be to read 200 to 2K, the 20K is to read 2K to 20K, the 200k range is for 20K to 200K and finally, the 2000K is to read 200K to 2000K or (2M) ohm resistance.
Basically, start on the high range, and work your way down until there is only one (or none) digit after the decimal point in the display for the best accuracy. A 6,500 ohm value may display as .006 reading on the 2000K range, and as you can see, doesn't give a true reading of the actual value.
I hope this helps!
Apr 12, 2012 | Gardner Bender Measuring Tools & Sensors
Black max 7kw generator high voltage output
Those voltage readings MAY be normal.
The AC waveform may cause your meter to read inaccurately. You would need to use a TRUE RMS meter to accurately read the voltage.
The siple meters actually read the AVERAGE voltage and then are calibrated to mulltiply it by the "form factor" for a sine wave. OFTEN these generators don't produce a clean sine wave. A square-ish wave will read higher on the garden variety meters.
Compare the brightness of a lamp comparing to when run on your utility.
The frequency depends on engine speed ... yours is running a bit fast...check it under at least half load and if off, adjust the govenor slightly.
May 01, 2010 | Briggs & Stratton Power Products 5,550...
I have a problem with panasonic kx ft938 showing "fax memory full". How can i clear it?
The memory is full of received documents due to a lack of paper, or a paper jam.
Install paper or clear the jammed paper.
or, unplug the unit for about 5 minutes.
or, to clear the RAM, try one of these procedures:
(If the first one doesn't work, try the next one)
1.
Press menu 7 dial dial dial dial * 6 start
Press up-arrow key until the display reads shipment set then press start
The display will read reset counter
Select yes or no then press start
2.
Press # 7 dial dial dial dial * 6 enter
3.
Press standby set dial dial dial dial * 6 start 9 9
On success, a long beep will be heard
4.
Press menu 7 monitor monitor monitor monitor * 6 start
Parameter 65 for memory collation should be set to invalid to maximize the memory page rating
Nov 27, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Mamiya M645j film counter not advancing to start when roll loaded
It's a common problem in the 645 - if you want to do it yourself, without a permanent fix, put a DROP ( not a lot ) of lighter fluid, or rubbing alcohol on the tip of a fine screwdriver and apply it to the gear you use to rewind the camera, and turn back and forth a few times. If that doesn't loosen it, it'll have to be disassembled.
Jan 07, 2009 | Mamiya 645 Medium Format Camera
I have a servis easi logic 1000 washer dryer combi and for some reason it takes roughly 5 hours to dry a small load, i have had someone look at it but they said everything was fine and they think that the...
There's all sorts of ways that washer dryers can get you.
Reading between the lines, I think you've got a situation where the machine is tumbling the clothes, is getting them warm (though not terrifyingly, scaldingly hot) and is eventually succeeding in getting them dry (rather than making them sopping wet). If those things are not all true, then read no further, but post again with more details of the symptoms.
This set of symptoms can be caused by the breather being blocked.
Somewhere, there will be a wide-bore (perhaps 1" / 25mm) tube that comes up from near the bottom of the tub (on my machine at home, it is attached to the bottom of the condenser, which itself is connected to the back of the tub at the bottom) and which runs up to somewhere near the top of the cabinet where it is open to the air. It is likely to have some sort of U bend at the bottom.
Try removing this tube and seeing if there's a plug of wet lint in the bottom.
A.
Dec 03, 2008 | Washing Machines
I have a 1985 300zx with a digital dash & analog miles counter---the speedometer & all digital systems work fine,except now the miles aren`t calculating,nor does the digital gas counter work which...
vetsr,
I believe there is an "amplifier" box, as you described, for the digital dash, I think under the dash towards the center console. Check out http://www.z31.com/ or call your local Nissan parts counter for exact location.. They should be able to tell you.
I don't know about the miles counter. If your speedometer works, it shouldn't be the speedometer cable. Sorry I can't help you on that.
My parts counter guy has always been helpful in trying to troubleshoot many issues. At least you should know his name.
Also, check out your local Z club. http://zcca.org/ and maybe
http://www.zcar.com/forums/
Good luck and happy motoring,
AlwaysRight
Jul 27, 2008 | 1988 Nissan 300ZX
Need CapturePerfect 3 driver for Canon Scanner DR 9080C
I have the same model Canon DR-9080C scanner which I recently acquired and I'm trying to figure out how used it is. I see many referrign to a counter. I see the big LCD on top front, but how do you know how many total pages have been scanned through it? I read somewhere there is a mechanical scanner. Is this true?
Jun 28, 2008 | Canon DR-9080C Path-Through Scanner
Imprinter won't work on DR-7580/9080C
May 31, 2008 | Canon DR-9080C Path-Through Scanner
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
