Question about Garden
How can I slow down the speed at wich u can walk with the machine it is a propelled mower. Thanks
  • 1,169 Answers
Depending the model some have adjustable cable length thus varying the forward speed. Check you owners manual for specific info.
Posted on Apr 05, 2015
    Top Expert:
  • Garden Master
  • 12,962 Answers
If the mower motor speed cannot be controlled, then you cannot control the walking speed.
And most transmissions are directly connected to the motor pulley so that if you slow down down the mower's motor, you also slow down the blade speed and cutting power.
Can I control speed of self propelled mower ?
most self propelled mowers should have a variable speed. the more you squeeze the handle the faster it will go. it is on a spring lever. as some people cant walk as fast as others. some just kick in at a set speed.
May 20, 2016 | Garden
How do adjust for Speed stability on Lawn-Boy mower. It hunts up and down.
Speed control for motor is controlled by an automatic governor, so there isn't any adjustments. Surging is caused by an air leak. Has the air filter been changed? Spray card cleaner around that side of the engine to find the air leak. Does it have a choke adjustment? Make and model would be handy in answering this question!
Oct 18, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Throttle on 14SZ not working, stays in low
CABLE STRETCHED..OR THERE WILL BE AN ADJUSTMENT TO CABLE SOMEWHERE...LOOK! SOMETIMES ADJUSTER IS AT LEVER..LIKE AN AUTO HOOD CABLE
Sep 09, 2012 | John Deere Garden
Husqvarna too slow when mowing
Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
May 08, 2012 | Garden
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Sens-a-speed mower rear wheels lockup when trying to push mower when not started or running
this means that the self propelled is engaged the whole time. so you need to somhow disengage it
Aug 19, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
