Question about Building Materials
Why does our door go up with remote but keeps running and wont go back down
  • 2,203 Answers
I do not know what you mean by keeps on running. but if it goes up on remote but will not go down on remote, it may be because the sensors are either not aligned or that a sensor wire is broken/disconnected. try pushing and holding the manual wired opener and see if the door closes. if it does, then that is the override for a sensor issue. good luck
Posted on Apr 07, 2015
Our door didn't go down completely last night. Unplugged and replugged. It closed after that. However it also closed randomly when we went to back our cars out. Any idea if this is something going bad...
Could be the logic board is going out. Also check all of the garage door opener remotes and make sure that is not the cause. Some people will keep and extra remote in a drawer and something will touch it and activate the garage door opener. Or sometimes people keep the remote in the drink holder in a vehicle and that will activate the garage door opener.
Feb 15, 2015 | Building Materials
My alarm refuse to cut off
When starting my truck it sometimes make a humming sound.
Feb 12, 2014 | 2002 GMC Yukon Denali
Window motors sounds
It sounds like the power locks are making the noise to me. First the power going to the window gets shut off when you shut off the key. Second the window will not make noise unless the cable for the window regulator is broke, then the window will go down and stay down or up and wont go much of anywhere. Try to hold the power lock button and listen for the same noise. Most of the time the one of the switches go bad and keep trying to lock the car. Its usually the one that wont lock or unlock.
Feb 02, 2014 | 2005 Chrysler PT Cruiser
My 2006 honda odyssey touring's Doors won't unlock with remote key. Central lock switch wont operate unless ignition is on. Everything works normally if the van's ignition is on or van is running
Do the other functions work on the remote, like will it lock the doors? The batteries in a 2006 remote should just be wearing down so maybe they need replacement. Do you have the second remote and if you do, is it working?
Sep 09, 2013 | 2005 Honda Odyssey
The switch works from the wall but with the remotes the door will start to go down then go back up. Sometimes with the remote the light inside will bink about 5 times and the door wont go down however I...
If the main light is flashing 10 times when the door reverses it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them if necessary. If you cannot get both lights to come on you have bad sensors.
Feb 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
Engine wont run due to immobiliser coming on and key wont overide
NO REMOTE,NO RESET.unlock door/hold over key,windows go down,then lock car hold over key.windows go up,then press remote unlock for 30 secs,reset done.
Oct 26, 2010 | 1997 Audi A4
When i hook up my amp my speakers wont play music? ive hooked up my rca cables up but i ont know if you hook it up to the input or output frum the cd player?
you rca hookup, back of cd player is rca out, at the amp it is rca in, make shure you hook up blue remote wire, also make shure you have a good ground if not amp will not turn on. if you run wires make shure you run power wire down one side of car and remote and rca down the other, This will keep all motor noise out of system.
Oct 07, 2010 | Audiofonics Car Audio & Video
2004 holden rodeo, remote control key wont lock/unlock doors
try putting key in ignition turn to on position
then press lock & unlock several times slowly if door locks cycle up & down after 1st press it lost code and is now resynconised.
now try remote with all doors closed and key out of ignition
if this dont work need to register key(program)back into system which dealer must do with Tech2 if round heart shapped remote
Apr 09, 2009 | 2004 Isuzu Rodeo
Gaarage Door
Have you looked on both sides of the door at the bottom there should be cables. If they are not tight you probably have a damaged spring. Look up between the door and where the roller mounts are, there should be a tightly wound spring. This is what keeps the door up, if tension is lost then it will come back down. If it is broken it needs professional attention.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
My door comes down part way and the motor keeps running.
Sounds like the gears might be out of the operator. If you can remove the cover see if there are white shavings in the cover. A Craftsman operator will take gear kit # 41C4220A
Jan 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
78 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
