Locked Door Light - after running the cleaning cycle the locked door light never shut off. Oven will not operate. Can not get any oven functions to start.
-   I had the same problem, started to do self cleaning but cancelled it. Opened thedoor and then "locked" started blinking. I thought maybe I can just wait it out since I just used the oven but no luck. But what happened was that when I was pulling the oven out, the over door unhinged a little and so it seems that when you pull on the oven door, the door lifts up! So, I lifted up the door and just snapped it back on top of the locker/hook. It was still blinking but when I re-tried the self clean - viola! It took a few seconds but it locked the door and started the self cleaning process- awesome. -   PINAY2000
Dec 23, 2007
-   I tried to clean the oven and the oven locked light came so it looked like everything was working. Then the cleaning cycle stopped (after less than a minute) and the locked light stayed on. Now, the locked light is on, the oven light is on and I can't work the oven - and I have nine people coming for dinner tomorrow! Help!-   dwright
Dec 04, 2007
-   door is locked but it is opened it won't close and light is on-   Guest
Nov 30, 2007
-   Our range has the "locked' blinking. When I try to run self-cleaning it is saying Door open? Ugh!-   Shewizard
Nov 26, 2007
-   Oven believes the door is locked, while it is not. Unable to start the oven, unless I use oven clean.-   StoveLock
Try this: turn off the circuit breaker to the oven. You are looking for a pair of breakers generally rated 40 amperes or more. Turn them off, wait a minute and turn them on. If that doesn't do it, then there may be a circuit board issue.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE Profile Spectra JGBP90 Gas
The oven and stop top comes on, but the glass stove top will not heat suddenly.
Had to turn the...
(More)
Had to turn the main breaker on and off, now the glass stove top will not heat. it indicates it is on. Help?
oven stopped baking when the temp. probe shut it off (as planned, at 165) but it won't bake anymore....
(More)
oven stopped baking when the temp. probe shut it off (as planned, at 165) but it won't bake anymore. I've removed the probe and unplugged the stove for 30 sec., but the gas still won't come on for a bake cycle. The broiler and stove work, however.
5 yr old pie wont get done ckd with thermometer and 50 degrees cooler than what was set. how do u...
(More)
5 yr old pie wont get done ckd with thermometer and 50 degrees cooler than what was set. how do u recalibrate oven temp?
I ran the self cleaning mode with no problem and now the self cleaning indicator light stays on and the oven will not come on. The door lock functions properly.
