Question about Dryers
Hi my dryer didn't get hot? - Dryers
  • 822 Answers
Check the thermost and or element...........
cheers
Posted on Apr 05, 2015
Maytag neptune dryer model mdg5500aww warm, not hot
Wow I just worked on one this week. Didn't take any photos. It had a bad wheel over the heater element. Was making a terrible racket.It was full of lint, so I gave it a good cleaning. I am sorry now I didn't take any photos. Your dryer might just need to be broke down and cleaned out. Most of these you are either gonna have heat or not. No in between UNLESS she needs to be cleaned out. To get into this beast (which is the most complicated dryer by the way to get into) you must work from the front of the dryer. Take photos of each operation so yall can get it back together correctly. First remove the door and since the door is reversible take the other 2 screws on the opposite side off. Then the goalpost shaped front just pops off. Next remove the shroud taking care to note where each wire to it connects. Ten get in there and release the belt and yank out the drum. Clean out the dryer and check if the blower wheel is loose. Oil the wheels with zoomspout oil. Safe for dryers and all major appliances.Suggest you sit the dryer on a workbench of a tailgate to clean it up. Since this is a gas dryer you will want to swap out the solenoids. If it heats some then the flame sensor and ignitor are working AND the fuse is not blown. The only other thang in the circuit is them coils which have a peculiar tendency: they work when cold but get hot and quit with age.
Slopefront Dryer Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 18, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Dryer gets hot but clothes has to run 3-4 cycles to dry
Check that you have emptied the lint filter, the container that catches the water from the clothes if it has one and also anything at the bottom that needs to be cleaned regularly. I had the same problem and didn't know about cleaning the filter at the bottom. I did this and all was well.
Aug 22, 2011 | Dryers
Hi, When i started the dryer lights were switched on but it didn't tumble at all.what could be the problem.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 18, 2011 | Whirlpool GGW9250PL Gas Dryer
Hi, My dryer does not get hot anymore. its blows cool and takes 3 hours to dry now. any suggestions. Clint is clean and not blocked also
Our Miele 9800 dryer didn't heat and we called the service technician from Miele. Our thermal elements needed to be reset. Pull the plug before you do this. Take off the small back panel with a phillips screwdriver. Reset the the three thermal elements. Put the cover back on, plug in and try again. A Miele is like owning a Mercedes Benz or a BMW. This is a high technology German product that needs attention at times.
Jul 18, 2011 | Miele T9800 Electric Dryer
Yesterday, I was texting my boyfriend... I was in the bath tub, but I was drying my hands off onto a towel... I didn't think much of it, because my phone has been dropped into the dogs water bowl by...
Try this :
Bring a hair dryer ,then remove your battery and sim card,then turn the hair dryer on (the hot air)
make the hair dryer focus on the phone from the battery side becuase there are some holes wich the
hot air can get inside the mobile and dry the mobile hard ware.
Make the hair dryer focus on the mobile for 5 minutes but be careful and make a distance between
the hair dryer and between the mobile to avoid damage the plastic mobile case becuase of hot air.
After five minutes turn the hair dryer off and wait until the mobile gets cold,then turn it on
This way is effective 50% to 90 %
If your mobile worked that means congratulations.
If it worked but not 100% that means there is improvement and keep drying it by the hair dryer as
i explained before,,,every dry for 5 minutes only.
But if it doesnt work at all ...that means your mobile needs a hardware repair and you have to send
it to a mobile repair store.
Jun 03, 2011 | Cell Phones
Dryer is not blowing hot air. There was water collecting in the vent hose which was emptied, but didn't help. Probably a heating element but not sure.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;';';'
May 24, 2011 | Malber TD700 Electric Dryer
Hi, i´ve been using a maytag dryer for 5 years. Yesterday when I tried to use it, the start button didn´t work... nothing happened when I push the start button. I checked electricity, but it...
heatman101
Oct 19, 2010 | Maytag Dryers
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
