Question about Miele Dryers
Can I change a Miele condenser dryer door hinge from the left side to the right side
I want to buy a Miele washer and condenser dryer and stack the dryer on top of the washer. The washer opens on the right side...and I would like the dryer to open on the right side as well
4 Suggested Answers
SOURCE: Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Posted on Jun 26, 2008
tzweeb
  • 318 Answers
SOURCE: washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Posted on Dec 28, 2008
tzweeb
  • 318 Answers
SOURCE: Can you switch the side the doors open and close.
sorry but the washer can not be changed. its strike has a lock and can not be reversed. the dryer can be changed, but the best thing to do is move the units and get some longer hoses for the washer.
hopefully you can switch the position of the units, but if not then you will be doing the laundry dance every time you do wash.
Posted on Jan 31, 2009
How to put top back on miele w1926
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
Dec 29, 2013 | Miele W1926A Front Load Washer
No problem w/5+-yr Neptune washer/dryer pair, they have served us well. But - washer currently hinged on the left/latch on right, dryer hinged on right/latch on left. Of course, the washer hook-up is...
If the doors were interchangeable I would expect that to be a selling point (!) and mentioned in the manuals ;-0)
The problem is that the holes for the hinges, the door catches, the electronics/electrics for the door solenoid and close sensors need to be available already on the other side. On top of those requirements the doors need to be the same internal shape upside down, as they would be upside down if swapped over to the other side.
So sorry, all in all it doesn't look good, does it ;-0(
John C
Apr 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
Can the door be reversed? ie open from left to right-----hinge on right side If so do you have instructions on how to do it?
Due to the shape of the washer door, and how it seats against the control panel, the door cannot be reversed on the Duet washer. There are no cut outs along the door opening to accommodate the door hinge screws and the door latch on opposite sides. The Duet DRYER, on the other hand, CAN be reversed. This may be an alternative configuration for you. Let me know if you want to know how to reverse the dryer door.
Jun 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you change the dryer door from a left to right opening to a right to left opening. Thid is a series 90 kenmore
Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
Feb 27, 2010 | Kenmore 659 Electric Dryer
Washer door opens with hinges on the left
Don't you think it would really boost sales if you did make a washer that the front loader door could open left to right . For homes that have very limited laundry room. and no way to switch.
Dec 28, 2008 | LG WM-2277HW Front Load Washer
Dec 28, 2008 | LG Washing Machines
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Whirpool duet front load washer door trouble
I have stacked ours too, though after 5 years we have not had any issues with the pressure. I would suggest checking the screws holding the hinge in place as they may have loosened or been tightened with the door not properly lined up.
Aug 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
119 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
