Question about Belkin Computers & Internet
I have a belkin wireless modem router model F7D1401 v1 and a week ago it would be normal then flash orange and stop working. however now it is a constant orange with the WPS button flashing orange.
    Novelist:
  • 175 Answers
I think you have the upper light blinking and lower light solid. Is that right? The upper light blinking means that the connection to your ISP is not working. Try unplugging/replugging the Ethernet cable in the top port (probably yellow and labeled "WAN" or "DSL" or something). Check the other end of that cable. If you have another Ethernet cable, try swapping it out.
If none of that works, call your ISP to check the connection.
Posted on Dec 11, 2015
  • 67 Answers
SOURCE: Belkin 54G won't connect to the internet
Are you sure your modem is giving a WAN IP from your ISP? Try power-cycling your modem with your router unplugged then bring up your router next, if you havent tried that already... After that try connecting your modem directly to a PC and set your NIC card to DHCP and see if you get an IP address thats routable to the internet (i.e not a private IP)
Posted on Mar 28, 2009
mcdevito75
  • 1970 Answers
SOURCE: why is there an orange
mcdevito75 here, The orange light could mean a weak connection to the internet, shut down and try to re-connect.
Posted on Aug 10, 2010
Geekman
  • 32281 Answers
SOURCE: I recently bought Belkin F7D1401
This type of problem can be caused by several interference problems. Please click on this link and follow my instruction to determine the cause and fix :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Posted on Jan 07, 2011
SOURCE: I have a Belkin N wireless router, model F5D8236-4
i have a belkin N wireless router model:F5D8236-4 v1 i have had it installed on my computer but it has since been wiped so there is no trace of me having it installed, since this i have moved home and ost the disk that came with it but i need to put the router back on due to my daughter having a laptop, how would i get the software for it if i have no disk?? please help!!!!!!!!!!!
Posted on Apr 06, 2011
josh_69r49
SOURCE: My BELKIN Surf Wireless Modem
Hi, Im sure you have prob solved this but I have the same modem/router and i found if you are using a torrent client with active downloads you cannot use multiple computers and browsing is slow/non-existant. Only way i found to solve this was to de-activate the firewall in the router set up since then i have no problems but it is not the best solution
Posted on Feb 27, 2012
Adsl link does not become stable, it shows blinking orange light
Reading the manual Troubleshooting section it looks like your adsl connection is not working. Try unplugging your internet provider's equipment power supply and waiting 10 to 15 seconds. Then plug it back in.If this doesn't work contact your ISP.
Mar 06, 2014 | Belkin Computers & Internet
Belkin f7d1401 v1
if internet is not working.
u need to double check that u have the right username and pw inside the modem.
Ur ISP should be able to help
Jan 06, 2014 | Computers & Internet
I need help with belkin n150 model F7D1401 V1 ..i can't connect to my network..i have a Huawei SmartAx Mt 882 modem..and i want to connect my network, wich is an ADSL one, to my computer..I can't...
Your MT 882 modem most likely has a DHCP Server that will interfere with the ip address of the router. Did you plug the Router directly into the laptop then go to dos prompt and type in ipconfig/renew . Or reboot the laptop !
Then type in 192.168.2.1 into browser
You need to work out the IP address of your 882 modem and then change the dhcp server leases on it to start at 20 like it might be 10.0.0.1 to 1.0.0.254 or it could be 192.168.1.1 to 192.168.1.254 .
if you are planning on using both devices on the network !
Make the Modem DHCP start at 192.168.2.20 to 192.168.2.254 and then make the Belkin router / modem ip address be 192.168.2.2 and the 882 modem 192.168.2.1 if you plan on using the two devices together on the network disable the belkin dchp server.
if you are using just the belkin then the reboot or ipconfig/ renew will be all you need .
Apr 25, 2017 | Belkin Basic Wireless Router
I, i am now connected to the internet with my wireless router (Belkin f7d1401 v1) but only via cable i can not via wireless. i have also digited 192.168.2.1 but now i dont know going further
You must login to the router and setup the wireless. Make sure you turn the WIFI broadcast on (enable it) so you can actually have wifi signal.
Dec 12, 2010 | Belkin Basic Wireless Router
If i change any settings in my networked pc's am getting net connection
For configuration of entire belkin routers including basic (f7d1301 v1) router...
And also for resolving various issues related to belkin routers...
click here....
Dec 09, 2010 | Belkin Basic Wireless Router
I have a belkin wireless router model #f5d9231-4 v1 and I tried to hook it into my cable modem to work wireless and the router wont recognize the modem
what do you mean it wont recognize the modem, it should just transfer the data from the modem threw the ethernet cable and convert it to wireless.
Jul 20, 2009 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
184 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
