Question about Nordic Track NordicTrack C2500 Treadmill
How do I fix a NordicTrack C2500 treadmill which went off during exercise and a blue light started flashing?
Power went off and a blue light started flashing even when I pulled the key away. I turned the switch to off, unplugged and waited for half an hour. When I tried again I got the same response.
  • 103 Answers
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ swflafitnessrepair@yahoo.com I will send this to you.
Posted on Nov 13, 2009
  • 103 Answers
SOURCE: NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
Posted on Dec 16, 2009
maxtreadmill
  • 832 Answers
SOURCE: I have the Nordictrack C2500, and for the second
You have a wire harness that attaches the upper board to the lower board. You may have to pull that harness thru the uprights ( Attach a fishing line so you can either pull a new harness thru or the original one ) and inspect it for snags crimps or broken wires also use a meter to a continuity check on the harness ends. Since the the command signals travel thru this harness also check all connections on the lower board. Its starting point
Posted on Jun 11, 2010
  • 218 Answers
SOURCE: NordicTrack 2500 R Treadmill
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Posted on Aug 11, 2010
ercupa190
  • 12223 Answers
SOURCE: NordicTrack Treadmill A2050, Will not work or turn on.
1) test the outlet wall , put a desklamp and see if work, if work the problem will be in the machine,
2) test the fuse inside for blown and replace with the same capacity
3) reset the circuit breaker inside.
4) test the power cord for open or defective.
Try again, if the machine NOT work, the problem will be in the power supply see the block atached.
God bless you
Posted on Sep 20, 2012
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
Jan 14, 2016 | Exercise & Fitness
I have a NordicTrack commercial 1750 treadmill. My console contols do not work and the ifit screen does not complete startup. What can I do to troubleshoot the problem?
The Controls Are Not Working on a NordicTrack Treadmill ...
www.livestrong.com > Sports and Fitness
Jun 1, 2015 - The Controls Are Not Working on a NordicTrack Treadmill ... Many glitches involving the controls on the console can be solved relatively quickly with some simple .... How to Use the iFit Videos with My NordicTrack Treadmil...
Nordictrack commercial 1750 that Icon can NOT fix - YouTube
? 3:52
https://www.youtube.com/watch?v=ILBbzyUXn2Q
Dec 16, 2011 - Uploaded by gerg6060
Nordictrack commercial 1750 that Icon can NOT fix ... I'll NEVER buy another Nordictrack again, Smooth or ...
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...1...
NordicTracktreadmill is not working properly. (See. TROUBLESHOOTING on ... COMMERCIAL 1750 treadmill. ... Console. Book Holder. Key/Clip. Power Switch. Walking Belt. Foot Rail. Power Cord ... Set the treadmill in a cleared area and remove all packing materials. Do not dispose of .... Each workout automatically controls the speed.
Dec 28, 2015 | Nordic Track NordicTrack COMMERCIAL 1750...
Will not turn on. flashing blue light
If the console only reads zeros or the controls do not function properly, try adjusting the reed switch. You will need a Phillips screwdriver to remove the motor hood and adjust the reed switch. Unplug the power cord, remove the motor hood and locate the reed switch, which is on the left side of the belt pulley. Rotate the pulley until a small magnet comes into view next to the reed switch. Loosen, but do not remove, the screw on the switch and move the switch with your hand until the gap between the switch and the magnet is 1/8 inch. Tighten the screw and replace the motor hood. The Controls Are Not Working on NordicTrack Treadmill LIVESTRONG COM
Feb 09, 2015 | Nordic Track Nordictrack C2500 Treadmill...
Steps to unfold
see the video and proceed according. God bless you
Nov 11, 2013 | Nordic Track NordicTrack C2500 Treadmill
Nordictrack c2500 treadmill troubleshooting
you must tight the ribbon cable and clean it. 2) clean the keypads from dirty, corrosion, and oxide. 3) adjust the REED switch see the diagram attached, clean it, and tight the connector very well.
Jul 21, 2013 | Exercise & Fitness
Flashing Nordictrack R400 AudioRider Display
https://support.nordictrack.com/exercise-bike-support/
Apr 05, 2017 | Nordic Track NordicTrack GX 5.0 Pro...
Hi, where can i get a C2100E motor control board for my Nordick Track C2500 ?
Two places either iconservice.com under replacment parts or Treadmill Doctor.com under treadmill products
Jul 19, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have the Nordictrack C2500, and for the second time the main board double beats when trying to start it. You press a button for speed, incline, the fan, anything and it double beats and won't start. The...
Jun 10, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
Feb 02, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack C2500 Treadmill Logo
60 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
