Question about Home
Shower tray overfills - Home
Im fitting a show tray in an en suite the stair way comes up underneath so if I fit the shower tray to the wall about 3" of the tray will poke through the plaster board showing above the stairs.
Hi Chris:
Sounds like you've identified the two logical choices.
It may be preferable to raise the shower for at least 3 reasons:
1) Headroom and aesthetics of the stairway ceiling will not be affected.
2) The installation of the shower drain trap will have more space available.
3) It will be easier to provide structural support for the shower base.
Hope this helps.
Cheers
Apr 05, 2016 | Home
Why does my keurig k10 leak?
It has an overfill tray to catch water when you put in more than 10 oz. When that tray becomes full it seems like the machine is leaking but the tray is just overflowing. Empty the overfill tray and try not to overfill. Learned this the hard way.
Aug 17, 2014 | Keurig Coffee Makers & Espresso Machines
Small crack in shower tray can i get a repair kit
Are you talking about the shower pan as in the part of the shower which you stand on? It is possible that you might be able to fiberglass the crack depending on the type of material which the shower pan (tray) is made of. Check with your local Home Depot for a fiberglass kit. Good Luck
Dec 02, 2010 | Home
Install plastic (fibreglass)shower floor tray. Do
no, they are designed to require no support. You may use small columns of expansion foam for added strength, but do not fill entire space with foam as it will raise the whole floor upon expansion.
Sep 22, 2010 | Home
Shower tray is low and fills before saniflow kicks in cant alter height of tray
See if you can adjust the highth of the saniflow,to make it kick on sooner. goodluck.
Jul 13, 2009 | Saniflo 013/005/007 Sanibest Toilet with...
Quadrant shower tray radius
hi i may be able to help?
if you take a carboard template of the tray it may better help you find one, you may not however get an exact match, but it may help?
kindly
Richie
Nov 18, 2008 | Home
Ice bucket/bin frozen in place
mine was overfilling because the ice was getting stuck on the way out. So some stayed in the tray and when the water would refil, it would overfil and go over the stuk cubes. leaving it to overflow to the bottom and freeze like yours.
Sep 09, 2008 | U-Line Icemaker
Installation Rules?
There are four golden rules for installing a shower enclosure. The first golden rule is to make sure that the shower tray is level. If it is not, then problems will occur throughout the rest of the installation. Use a good quality spirit level and where possible install a tray that has adjustable legs. There are often problems associated with tiling over upstands as some are thick and difficult to set into the wall. The second golden rule is to install a tray that has a slim tiling up stand which is vertical and an integral part of the tray: This will make the installation easier, quicker and ensure it is totally watertight. Before installing the shower enclosure the third golden rule must be followed. A silicone sealer needs to be applied all the way around the join where the tiles meet the tray: This must be sealed first, to ensure there is no chance of water getting behind the wall channels and then into the walls. This is one of the biggest problems associated with shower installations but is easily solved if the silicon sealer is applied before the enclosure is fitted. The final golden rule is to fit the enclosure to the tiled surface and not on to a plastered wall, tiling up to it afterwards. Having installed the enclosure it is essential to use the same high quality silicone sealer around the outside of the enclosure. Sealing on the inside will cause leaking- not prevent it.
Aug 27, 2008 | Dynasty Hardware Pacific Shower Basket or...
Home Logo
99 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
