Question about Home
Overfils shower tray. Does not seem to pump out fast enough
No shower pressure in rv
Make sure you have enough water in the tank or city water hooked up. A pump will run and suck air if the level is low. it could force water to the sink, etc, but not the shower.
Are your valves for the water pump set correctly? Remote possibility someone installed a shut-off valve between the pump and shower.
Could be the pump is getting weak/leaking internally and can't build enough pressure.
Make sure the shower head is not clogged. Remove it from the hose and try again.
Apr 22, 2014 | RVs
Machine keeps icing up and switching off
When you say ices up do you mean the line ices up back to the compressor. is water overflowing over sump tray? or is it dumping out drain? If you are not getting water over the evaporator plate then it will frost up the evaporator plat all the way back to the compressor.if the water is dumping into the drain during freeze cycle check the dump valve this will not let sump tray stay full of water. make sure water filter is good as this will not let sump tray stay full fast enough. is water pump pumping water over the evap plate?
Jan 03, 2014 | Kitchen Appliances - Others
Water is flowing back to shower tray macerator not switching on
Usually Saniflo requires 8" or 9" from top of p-trap to floor level, not from top of shower base to floor level. If the base is raised 8" then you will have enough room to fit a p-trap without cutting the concrete, if you had cut the floor to fit the p-trap then the base is not raised high enough to maintain the water pressure inside to engage the unit.
Mar 22, 2013 | Saniflo & Saniplus& Macerator Pump
Shower tray is low and fills before saniflow kicks in cant alter height of tray
See if you can adjust the highth of the saniflow,to make it kick on sooner. goodluck.
Jul 13, 2009 | Saniflo 013/005/007 Sanibest Toilet with...
Pumping stopped
Well it sound likes you have 2 problems. 1st is the float switch is set to high,and pump wont come on till it raises higher then tray. 2nd. sounds like empeller came lose from shaft. I hope this help. :)
Jul 05, 2009 | Saniflo & Saniplus& Macerator Pump
Oil doesnt return to oil pan fast enough
If all the engine oil passages are unostructed and clean, you will have to try a lower volume oil pump. Some high performance engines are painted internally with special paint to reduce friction and smooth the down the oil flow down back to the pan.
May 30, 2009 | Ertl 1970 Ford Mustang Grabber Yellow 1:18...
Home Logo
91 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
