SOURCE: electric shower is not getting hot
Locate your electrical panel box, find the breaker for the water heater, turn it off then back on, locate the water heater. Fins the powere disconect. Sometimes they are a simple pull disconect or switch, sometimes they are another breaker or fuse.
Check the fuses or flip the breaker if aplicable.
Do you have a volt/ohm meter?
SOURCE: triton opal electric shower overflow pipe
hi rob the problem is due to an activated thermal overheat switch, you cannot reset this unit as once it is activated it will require a new unit, its a nuisance i agree as i come across this regularly, however its condusive of a scaled up unit so you eventually turn up the shower setting higher to get the water hotter, & inturn activates the thermal switch.
According to which model it is the part is not that overly expensive, you can phone triton direct 7 they will post a new spare to you
Kindly
Richie
SOURCE: my shower works. water also poors out of a tube beneath the unit
Are you talking about water still coming through the spout at the same time? What overflow pipe are you talking about? If you are talking about the spout, there is a device in the spout that when you pull up on it, the water is diverted to the shower. They have washers in them and it sounds as though the washer is worn out and not making a good seal anymore. You can buy a new generic spout to stop the water or you can take the old one apart and try to find replacement pieces. I have taken one apart and bought a new one to rob the parts off of it before. I hope this is the answer you were looking for. If not, reply to this for clarification and I will try and answer your question more clearly.
SOURCE: The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
SOURCE: Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
