Question about Konica Minolta Office Equipment & Supplies
Hi I have a Konica Minolta C-550 I appear P. -21 code After I changed the UNIT appeared to me Code P. -5 What should I do
  • Konica Minolta Master
  • 6,161 Answers
I am going to assume you replaced the Transfer belt and transfer roller. Since you did not state that in your input. You did replace both at the same time. Cleared the counter for the transfer roller in the service mode?. Anyway the code P-5 and P-21 have to do with the registration sensor located below the transfer belt. On the right side of the machine. Where the edge of the belt is and exposed below the belt and behind the large plastic part below the belt there are two sensors one to the front the other to the rear of the belt, again below the belt assembly. It will require you the expose the sensors clean them. Worse case have them replaced, or the Main board!!!!. Recommend you have a Konica Minolta tech come out and do this procedure. P-5 is the front sensor failure
Posted on May 13, 2015
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
jqsababa967
  • 145 Answers
SOURCE: C-D370 error code for Copier KONICA-MINOLTA C252
this has to do with what they call NAVRAM IS C
To troubleshoot the error:
1. Reset the code by pressing stop-0-7-1-3-9. This will display a "*" on the LCD. Press this button.
2. Perform a Data Clear and then perform the Setup Procedures from the beginning.
3. Perform a NVRAM Recovery Procedure. Please see attached document. To view the PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for free from RRUPTED/need to be reset BUT that will clear all the current setting especially if print to it.if you are willing to try ....
you should have a Tech do this...
good luck
Posted on Sep 20, 2009
djklermund
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
While doing printing after 6 or 7 print, the error code c2552 appear in konica Minolta c220, I have open the front door, after that error gone, Again same problem coming after 6 or 7 print.
C2552 Abnormally high toner density
detected Cyan TCR Sensor
• TC ratio in the developing machine, which is
determined by Toner replenishing amount control
mechanism, is 12 % or more for a given number
of times consecutively.
1Clean the TCR Sensor window on the
underside of the Imaging Unit if dirty
2 Reinstall Imaging Unit
3 Change Imaging Unit
4 Change PWB-M
5 Change PWB-MFP
Jan 24, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 282 c2557 code appears after F8 ran and new related parts were replaced?
Did you replace the developer unit along with the new developer? mite have bad ATDC sensor bottom of developer unit
Sep 21, 2016 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
C244e prblem for p 21 errof code
Replace the black drum and black developer unit P-9 Black drum issue and P21 registration issue since black is used as the reference for registration of colors can see a P-9 and P-21 code combo. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 13, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Me problem is code c03ff
Hello by mistake you have changed the copier model ..
hi...this error code appears after you clear the data in service mode...so you have to enter sevice mode
Utility+stop+0+0+stop+0+1....enter to ADJUST &specify the speed model from the table find 21-18-16
select the model you have
Feb 27, 2014 | Konica Minolta Office Equipment & Supplies
CODE F51_2
F-51-2, This error code appears in following copier models.Konica Minolta 7222/7228/7235/7135/7145This error code means "Fixing unit motor speed abnormality"Fixing unit drive motor is Motor Number 11.M11.Open the back cover and remove the main board and there you will find this motor.
Jan 04, 2012 | Konica Minolta Office Equipment & Supplies
P-21 and p-5 error message. and fully cyan color comes.
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
Nov 27, 2011 | Konica Minolta bizhub C250 All-In-One...
ERROR CODE C-4401 On Konica Minolta Bizhub 500
CAUSE: Failed write unit. Laser
Replace write unit (p/n 50GA-6500).
Feb 19, 2009 | Konica Minolta Office Equipment & Supplies
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
