Question about Water Heaters
My rads come on when i turn the hot tap on for a shower.even when the central heating is turn off?can you please tell me why.thank you
  • 21 Answers
Suggest the heat exchanger may be furred up inside
Posted on Apr 13, 2015
  • 104 Answers
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
mixing valve must be replaced
Posted on Nov 02, 2008
  • 3 Answers
SOURCE: combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Posted on Dec 30, 2008
gary1121
  • 332 Answers
SOURCE: Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
Posted on May 30, 2009
gary1121
  • 332 Answers
SOURCE: easiboost power shower - problem
it comes on when the pressure changes so when you open another faucet it changes the pressure and makes it come on,, check your pressure regulator valve on the main line comming into the house it has a screw in the center, if you have a pressue gage put it on either the water heater drain or out side hose bib , check the pressure when turning water on and off if it changes more then 5 lbs you need to change your prv valve. pressure regulator valve,
Posted on Jun 06, 2009
  • 4 Answers
SOURCE: low pressure on hot water taps and showers
Many states building codes require a pressure regulator and expansion tank for hot water heater installation. Check the pressure regulator if you have one as this would only affect the hot water pressure. Adjust or replace. Rap the expansion tank like knocking hard on a door. Hollow sound is good. Dull thud means it needs to be replaced as it is filled with water.
Posted on Jun 24, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
When I have central heating on, why do I also get very hot water in taps even though water heating switched off?
This could be due to incorrect installation, incorrect wiring of controls, or an unintended consequence of combined central heating and hot water supply.
Nov 27, 2015 | Water Water Heaters
I have to turn the hot water tap on full open to get hot water
Type of water heater is unknown
If you have single-handled faucet the faucet cartridge might be bad.
If you have recirculation system, then check valve might be bad.
Copy following links for troubleshoot.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Jul 16, 2012 | Water Heaters
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Heatslave diverter valve
clicking rads are due to pipe expansion when getting hot.
If the hot water [secondary circuit] gets hot and the boiler stays on [does not keep going on and off] even with a constant low water flow then the diverter should be ok.
there is a valve to prevent the primary circuit [central heating] [ CH] from sending water to the rads. this or its control may be at fault.
both the
Both the CH pipes to & from the boiler should have manual valves to turn off. do this then try the hot tap-full on. If the boiler goes into overheat mode and the overheat stat kicks in to turn the boiler off -- then :-
Check also the heat exchanger, it may be furred up especially if you are in a hard water area. It means taking it off and manually checking [pour water through] If you're lucky it will be just muck to be forced out with hose pipe pressure, if not a new one
Sep 06, 2009 | Water Heaters
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Aug 09, 2009 | Water Heaters
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
May 18, 2009 | Water Heaters
Water Heaters Logo
107 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
