Question about Refrigerators
The fridge keeps freezing - Refrigerators
  • Refrigerators Master
  • 5,323 Answers
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM
Posted on Apr 07, 2015
Fridge section keeps freezing up.
Hi,I had trubble with my fridge so done a bit of reserch the main reason for the fride freesing up is,
fridge not set at right temp (3 to 7 c ) or vent where water drains blocked,shelves not in right place as in manuel,and if you put veg that has alot of mosture content can also course freezing at the bottom of the fridge,hope this was some help,maybe buy a fermomiter to test.
Jul 03, 2016 | Refrigerators
My beko fridge freezers fridge keeps freezing
Your t'stat is probably bad. Should be easy to fix. At least it is freezing and not ruining your food from being too warm.
Feb 03, 2013 | Refrigerators
Fridge keeps freezing up have replaced motherboard
What is the model number of your unit?
Nov 23, 2012 | Refrigerators
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Jan 05, 2010 | Refrigerators
Hotpoint larder fridge RL150G keeps freezing at the back fitted n
flap controling tempature not closing to controle tempature 9inside ref
Dec 09, 2009 | Refrigerators
Salad in salad tray keeps freezing
contact the people who made the frig, sounds like a service call might be needed. you are paying for food that is destroyed, the service guy may save you money in the long run.
Oct 03, 2017 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
If u change the thermostat and it keeps freezing the heater or timer are bad
Jul 24, 2009 | Westinghouse Refrigerators
Liebherr fridge 3150 keeps freezing
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Mar 03, 2009 | Liebherr KELB 2840 Premium biofresh...
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
