'not enough memory to perform operation. delete some data first.' this is the one appearing on my nokia screen.
SOURCE: NOT ENOUGH MEMORY TO PERFORM OPERATION.DELETE SOME DATA FIRST"
I think you installed the virus in phone. You need to hard reset your phone. Back up your data on your phone e.g. contacts, tones, images and videos.
WARNING ALL DATA ON YOUR PHONE WILL BE ERASE.
Here’s how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see the hand animation is displayed.
SOURCE: memory low n70
You need to change default storage device on your phone, from phone memry to card memory. In other words, move all data (messages, songs, videos etc) from your phone memory to card memory.
for example, go to messages>options>other>momory in use - change it to memory card instead of phone. (if your memory card is not named, it will be displayed as NO NAME).
Do the same with other data also.
SOURCE: memory full, delete some data
If you Memory card is also full. Backup all your data to your PC and delete some data in your mobile.
Hope This Helps!!! Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
SOURCE: when i switch on my phone , an error message appears
This error refers to the amount of free space under "Phone Memory".
As in, the 44mb of built in storage.
Just Delete any number of these, including:
If this doesn't solve the problem, back up your stuffs then reset the phone using
*#7370#
I hope this helps :)
Best Regards,
James Trageser
SOURCE: I have N 72 phone. No operations are being
try to rest.Make sure to back up your important files like contacts.On the main screen type *#7370# it will aks for security code then just put it on. hope it helps
