Question about Fisher and Paykel Washing Machines
When I set machine on cold wash the water is hot and vice versa. How can I fix this?
I try and do a cold wash and the water runs into the machine as hot, and vice versa. The hoses are connected to the correct taps. How to fix this?
    New Friend:
    Problem Solver:
  • 18 Answers
Reverse the water supply hoses either on the wall or on the machine. be sure to turn off water valves first. or just wash hots in cold etc. :-)
Posted on Apr 05, 2015
Need to know what HC means on my washing machine Kenmore Elite Oasis. wash did come thru from the bottom
hi there
HC means that the water hoses have been changed or the hot is in the cold and vice versa. put the hot water to the hot on the machine and the cold to cold and this will stop the HC code.
and on another site
The "HC" indicates that the Hot and Cold water supply lines are reversed. Shut the cold and hot water supply valves off and then remove and reverse the hot and cold water fill hoses on the washer and then see if it continues to display "HC".
what HC means on my washing machine Google Search
Aug 07, 2017 | Kenmore Washing Machines
Tried to do a load of laundry and the water doesn't seem to come. The machine beeps and flashes F and then H or vice versa
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 03, 2011 | Kenmore Elite 45986 Front Load Washer
I set the water temp setting to cold, but it keeps filling with hot water. No matter where I set the dial, it fills with hot water.
check whether the hoses are mismarked when they come out of the wall.
the same thing kept happening to us (whirlpool cabrio) and i checked the temperature on the hoses coming out of the wall - cold was mislabeled as hot by the builder, and vice versa.
Aug 31, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Cold/cold wash uses hot water wash and warm rinse. I have t set to hot/cold wash to get cold water wash.
probably the water inlet hoses are hooked up cold water line to the hot water inlet and vice versa
Aug 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag washer has a water temp. problem I,ve replacrd the water temp switch (pt.# 37001263) 4 pole switch several times but the problem still returns I,m getting hot water insted of a cold water...
You say that you are getting hot water instead of cold on rinse... Does that mean that when you select hot water wash you get cold?
If so, the machine 'thinks' it is giving water that is the wrong temp.
You may be sure that the hoses are the right way round, but if the water temp is opposite to what it should be, there's obviously something amiss!
Try swapping the hoses and see what happens...If the hoses are 'right', it could be that the water inlet valves are 'wrong'. It could be that the 'cold' wires are on the 'hot' inlet valves!! & vice versa
Good luck....Nomess
Aug 05, 2010 | Washing Machines
Water is too hot
My hot and cold is reversed. The red handle is on the cold and vice versa. Check that out first.
G.
Apr 15, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Took water intake valve assembly out to replace - confirming white wire connectors go on the cold and the black on the hot ?
Try it the way you said if it that doesn't work reverse connections. No damage can be done. You'll get cold water if asking for hot and vice versa.
Jul 05, 2009 | Kenmore 44832 Front Load Washer
Bosh error code E02
Hi. I had the same problem with my Bosch washing machine and called Bosch...was told the same thing...$99.00 for service call. I managed to fix my problem by doing the following:
  • Removed hot & cold water supply hoses.
  • Took filter screens out of both hoses.
  • Removed filter from cold inlet on back of washing machine. I noticed some oily buildup on both of the cold screens so opted to not put any of them back in.
  • Then I put hot & cold water supplies back on the wall hookup, but crossed the lines where they came into the back of the machine intentionally so that the hot water line fed into the cold side of the washing machine and vice versa.
  • Then I ran a couple loads on "cold" which was actually hot water coming in to the machine.
The reason I did this was that I figured there must be some more waxy buildup inside the machine in the cold lines and hoped the hot water would melt it like when you rinse a greasy pan under hot water. IT WORKED!!! I hope this helps you.
Sep 29, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
49 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
