Question about Video Game Consoles & Games
How to connect xbox 360 to component? - Video Game Consoles & Games
    New Friend:
    Problem Solver:
  • 5 Answers
The standard video cable should have two branches, one with 3 plugs, red, white, and yellow, the other with 3 plugs that are grey, with stripes labeling them as red, green, and blue. These are the component video connections. You plug those 3 into the corresponding colored inputs on your TV, and you use the red/white plugs from the other branch for the left and right audio. Then, just make sure the switch on the end of the cable that plugs into the console is switched to HDTV, and you are good to go.
Posted on Apr 05, 2015
Testimonial: "I have 5 RCA (green,blue,red,yellow and white)with one HDMI I can't connect TV to xbox 360 by this cable"
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
http://support.xbox.com/en-AU/xbox-360/system/connect-xbox-360-console-tv
https://www.youtube.com/watch?v=JlE2zHSoQmE
Nov 20, 2015 | Sanyo DS31590 31" TV
Connect xbox 360 cable tv?
Use an HDMI cable, component cables, or composite cable that were provided with the xbox 360.
Sep 06, 2014 | Video Game Consoles & Games
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
When I turn on my xbox 360 I get sound but only a
this seems like a component cable issue, are you connecting the system to an hdtv? if so check the component connections to make sure its connected to the proper ports.
May 21, 2010 | Microsoft Xbox 360 Console
Can xbox 360 be connected to suuround sound
yes! plug component cables (RED/WHITE)
in an AUX port in a surround sound system...select AUX on your system..
plug YELLOW into TV
play!
Feb 07, 2010 | Microsoft Xbox 360 Console
Xbox 360 hdtv connection help!!!
Yes, you will need HDTV compatible AV cables.
Jun 25, 2009 | Microsoft Xbox 360 Console
CONNECTING XBOX 360 TO SAMSUNG HOME CINEMA SYSTEM VIA OPTICAL
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
Jun 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
XBOX 360/SAMSUNG PLASMA TV
If you have an Xbox 360 Elite or a newer Xbox 360 Premium, you should use an HDMI cable if your TV supports it. Otherwise use a component cable.
Nov 25, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
55 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
