Question about Mackie Audio Players & Recorders
How to solve the reset problem of hd1221 mackie speaker (?).
Hi my mackie thumps 100 watt aren't delivering a decent volume ,,I,m using mackie mixer please help
Is this a new problem? In other words, was it working correctly at some point?
You ned to isolate the problem. Plug a different source into the speakers and plug the mixer into a different amp/speaker. See which part isn't working correctly.. Either way, it's likely you need to take the part that's not working to the shop. You can contact Mackie to find the nearest service center. Service Locator Mackie
Nov 28, 2016 | Mackie Music
Mackie srm450 v2 no top end.
Check the aspect of the crossover filter for the speakers, inside. Sometimes they fry.
Apr 14, 2014 | Mackie SRM-450 System
How to replacea bass driver in mackie thump 15a
"How to replace bass driver in mackie thump 15a".
Did you mean,disassembly the speaker enclosure?
Just remove the 16 screws at the rear cabinet, using a screwdriver.
Then remove the 4 screws that secure the speaker, using the hex key. Is the bass driver blown up / broke?
Jan 28, 2014 | Mackie TH-15A Active DJ Powered THUMP...
My Mackie 450 turns itself off why
Be aware that TIMED TURNOFF button at the back of the speaker is off otherwise every time sound level is low the speaker can go off by itself.
Dec 16, 2012 | Mackie SRM-450 System
I have a hole in my mackie sub How can I get a
See the link below to either locate a dealer close by or to contact Mackie directly for the parts.
Dan
Link: http://www.mackie.com/support/
May 09, 2010 | Mackie SWA1501 Subwoofer
I have dropped one of my mackie srm450 speakers and i need a replacement woofer.. where can i get one?
If the cone is damaged, it is possible to get it 're-coned'. If you can find a shop that does this type of speaker repair.
Otherwise, call around music stores (by that I mean places that sell musical instruments and PA gear) and see if they sell/sevice Mackie. If you are comfortable taking the old woofer out, just order the part and DIY.
It is not critical that the woofer is an exact replacement (doesn't have to be a Mackie speaker), the important things are:
1) it fits and screws back into the speaker cabinet
2) it is electrically similar to the original (same impedance 4 ohm or 8 ohm) and wattage rating
Feb 06, 2010 | Mackie SRM-450 System
Mackie SR1521Z powered speaker quit working
The resistors you require are 6.8R 1 watt carbon 5%
the colour code on them is blue grey gold gold
Jan 30, 2010 | Bob Mackie SR1530 System
Repair a Mackie SRM 450 Speaker The Speaker is making a crackling sound while playing. The sound keeps cracking up.
You probably need to replace the diaphragm. The diaphragm is located behind the back cap. Simply remove the back cap, remove the diaphragm, clean the voice coil gap with a piece of masking tape, install a new replacement diaphragm, reinstall the back cap. That it!
You can see videos on how to replace diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-c/INST/Installation+Instructions
You can buy a new Mackie SRM450 diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-cp/SRM450-DIA/DIA-Mackie/Mackie/
Jul 20, 2009 | Music
Mackie srm450 not making any sound at all
It sounds like the thermostat didn't shut the speakers down before they were damaged. There is probably a very fine wire leading to the speaker coils which is burned/broken. Fixing this broken connection my solve the problem unless the coil itself is damaged.
Another possibility is that the crossover circuitry in the speaker cabinet is damaged from overheating.
Sounds like you need a service tech to look at the bad speaker, unless you want to tackle the job.
Apr 22, 2009 | Mackie SWA1501 Subwoofer
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
