Question about Hoover Washing Machines
Agitator Does not turn left direction..
I have Hoover 700LC washing machine almost 12 yrs. only couple of months i noticed that when i started the full cycle for washing, it turns to right side & left side dosent. I can see that it trying to turn to left with hard effort with bit of sound of wheel,But its rotating very slowly to left direction. But after couple of hard turns, which i could say 10-15 hard rotations, then its back to normal washing cycle with out any noise. It works left and right directions very well until finish of complete washing period. But if i stopped for a while for 30-45 minutes then again agitator does not turns to left.It makes same noise like before. I replaced the belt last month. It is original belt.But it dosent solve this problem. Please could you kindly response to this problem Thanks for your time. Maha. mahagemunu@hotmail.com
    Genius:
  • Hoover Master
  • 1,585 Answers
Gear box
Posted on Apr 12, 2015
  • 1073 Answers
SOURCE: Spin Cycle (again) on Whirlpool Washer - Bad Noise
then the transmission is bad the part number is 3360629 since you know about the drive coupling the you know wher the transmission is all you need to do to change it is
remove the agaitator
move pump to the side
drop dow the motor
remove motor wiring at switch
remove the retaing clip from the transmission for the motor wiring
the tranny is held in place with 3 half inch headed bolts
reinstall backwards and you are good to go
Posted on Apr 16, 2008
  • 24 Answers
SOURCE: Hoover Washer only agitates in one direction
Check the paw. It is a plastic somewhat u shaped piece that sits on the bottom of the machine and is connected by a plastic lever and a solenoid. It usually breaks on the end and as such won't lock the gearbox in. If you keep running it like that there is every chance you will probably burn the motor out.
Posted on Oct 08, 2008
aborcass
  • 2651 Answers
SOURCE: Loud noise during spin cycle and agitator won't rotate
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Posted on Jan 26, 2009
  • 113 Answers
SOURCE: kenmore 80 series washing machine agitator will not rotate
you need to replace the agitator dogs, very simple. Go to www.shop.washermd.com and download the tutorial, thanks
Posted on Mar 03, 2009
  • 208 Answers
SOURCE: Kenmore elite washer will not complete not complete wash cycle.
worn gears
Posted on Jun 22, 2009
How do I remove the agitator from my Hoover 201M washing machine. It really needs to be cleaned under there with all the muck thats building up. Thanks.
if it is a top loader machine with an agitator that stands up in the center of the tub, try removing the dispenser and lint trap from the center ( normally just a pull up) and right down the bottom there is a 10 or 12 mm bolt that you undo and that allows you to pull the agitator up off the drive shaft
talk with a service agent as to how to get the agitator out or down load a workshop manual from google by typing in --workshop manual for hoover model 201m washing machine -- and if there is a pdf version then down load it
Feb 07, 2016 | Hoover Washing Machines
Why is our machine not washing as normal ?
Have you trued clearing the drain at bottom of machine? If not that, it sounds like a programmer fault.
Jul 21, 2014 | Hoover Washing Machines
I am looking to buy a used Frigidaire GLWS1233AS2 Top Load Washer and GLER331AS2 . They are supposed to be 3 years old. Are they good machines or do they have lots of problems?
Mine is 10 yrs old and I am just now having a problem. Clothes are too damp after last spin cycle. Hopefully, I'll get an answer here soon. Another problem I noticed a few months after I got it, with this model, is the fabric softener dispenser on top of the agitator. You have to remove it every single time and clean it. I added a little water to it before adding fabric softener and thought that would help to stretch the cleaning to maybe once or twice a week. Don't do it! I started to smell mildew and found out why. The agitator shaft that this dispenser sits on was caked with old fabric softener. I just use the blue Downey ball now. The fabric dispenser stinks but I have had 10 yrs of good washing.
Feb 14, 2013 | Frigidaire GLWS1233A Top Load Washer
Hoover 700lc is putting grease on clothes
The only part of the washer that has oil or grease is the transmission. This is a very bad sign because it says the transmission is leaking and the center seal is also letting the oil grease come through. I would start looking at new machines because it wont be cost effective to repair if you pay a service comapny and if you've never done one its not something you want tot learn on.
Apr 28, 2012 | Hoover Washing Machines
Rubber coupling is getting shreddedprevents agitator from working
no it's not a recurring problem. Q. Can you spin the agitator freely in both directions when the machine is off? Please post the entire model number 110 is just the first 3 didits.
Apr 11, 2009 | Washing Machines
My Kenmore series 70 washer will wash and then the machine stop. If I move it to the rinse cycle it will start agitating again and then it will shut off again. It seems li9ke the spin cycle isn't working
Welcome
Either of these three problems may be occurring.
Faulty Direct Drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Thank You Please remember to leave a rating.
Dec 12, 2008 | Kenmore 23822 Top Load Washer
Hoover Premier 706
I have the same washer and the paint started to flake from the bottom of the bowl. Rust under the baked enamel made it lift. I peeled the loose paint then applied rust converter and a zinc paint. This patch is still ok after 12 months but my wife is complaining about paint flakes and rust on some clothes. In my opinion, the only way to remove the agitator is to undo the nuts retaining the shaft from the inside. I guess I will find patches of rust under the agitator and depending on how big and deep they are will determine if I replace the machine or patch the rust.
Bob
Sep 03, 2006 | Hoover HTC243 Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
