Question about Motorola Talkabout SX600R Handheld Two-Way Radio
I'd like to find a couple of mic's for my sx600, I like my radios. I am a ham radio operater, it does help.
  • Motorola Master
  • 3,957 Answers
Hope this is the type your are looking for: https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=sx600+microphone&tbm=shop
Posted on Apr 05, 2015
Testimonial: "Thank-you, 73's. n9vsh clear."
  • Official Brand Answer
  • 3,100 Answers
Brian
You may consider contacting Get Support at Motorola Solutions or a Ham Radio interest group online. Probably too specific for FixYa.
Mark
Motorola Mobility Support
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Push to talk problem
If indeed radio #1 has a mic problem, this may be confirmed by trying an external speaker/microphone plugged into the accessory jack. If still a no, then its not the mic but possibly the modulator circuitry. If there is transmit audio with the external mic and hence internal mic is defective, the unit would have to be pried open and the defective component replaced. The internal mic is normally an electrofet 2-3 terminal soldered to a shielded wire and physically attached to the front plate.
Alternately, another possibility is that radio #2 has its Interference Eliminator Code enabled/activated. This is indicated by the presence of small sized digits on the top right of display. If this is the case and no similar digits are displayed in radio #1, then radio #2 will not allow any received transmission to be heard. Along the same line of reasoning, if the code is activated on both radios signified by the presence of the 2 small digits, and radio #1 has a problem with its CTCSS (code) generator, then it would also prevent reception of radio #2. A way to verify this is by deactivating/disabling the Interference Eliminator Codes on both radios.
On certain occasion, it is also possible that radio #2 has a defective speaker. You should be able to verify this by plugging in an external speaker to the accessory jack of radio #2.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 10, 2007
Need mic wiring for d104 to tempo 2020 4 pin
Hi Gregory. Info is a little sketchy on this unit but I'll give you what I found. This 1st one has some general info about this unit along with a couple of links to alignment instructions.
RigPix Database Other ham radios Uniden 2020
This 2nd one has a instruction manual (in pdf format) which shows a pic of the mic plug on pg.5.
http://www.rigpix.com/mischam/uniden_2020.pdf
That's about all I got, hope it helps,, Mike
Oct 18, 2015 | Radio Communications
What would cause the mic amp to blow out after keyup of less than 12 times,replaced amp 3 times with same results
Are you using the stock mic, or have you switched to a so called Power Mic? These can kill the microphone preamplifiers in some radios. All a power mic is going to do is to create splatter on any type of radio if it is not set up correctly. It will not give you more output power in SSB or AM, but it will make you unpopular with other operators. HAM and some CB radio's have some front panel controls that can help with this (mic gain). What it comes down to is that the mnufacturer specified a certain mic that will perform properly, and any additional microphone that you decide to use should be set up appropriately for the radio.
Mar 04, 2015 | Radio Communications
Mic wiring for tyt -9000
since this is a fairly new radio, your only resource is your manual and schematic.
As a Ham you should be able to read them. If you are thinking of installing an aftermarket mic, you don't do this on most ham radios, they are not CBs that you can put a "power mic" on. too much audio input on an FM transceiver can make your transmission unintelligible
Oct 12, 2014 | TYT Electronics TYT TH-9000 VHF...
I have a yaesu ft2900 ham radio when i key the mic it turns off then comes back on help
You have all the making of not enough power to operate the radio and it shuts down to protect itself. Hook the power leads directly to the battery terminals and keep the leads as short as possible. The more wire you have the more resistance and the more resistance the less volts your radio can see. Also be certain you have a good ground connection
Apr 15, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Replacement mic.
Check with "Ham Radio Outlet" online. They should have a replacement.
Feb 22, 2014 | Yaesu FT-726R Transceiver
Wiring a mic to a ham radio.
Get the schematics, isolate the circuits, and apply the fix. But... You probably want all those details.
Dec 07, 2013 | Kenwood TM V71A VHF/UHF Mobile Dual Band...
Will a cobra power mic cure the low mod on my cobra 19 dx iv eu or will it blow the front of the rig
that is simply bs, Ham radio shops rarely like CB people (I am a long time cber and also a ham.
On that radio there are two things you can do, look for the mod limiter and remove it or another more simple thing:
This radio comes with a 1000 ohm element in the mic--like speakers---Get a older or new 500 ohm microphone and wire it or have it wired for the 19 dx, it will make a big difference in how it sounds.
I not only worked on those radios but sold them in a shop I owned.
You might find a used mic that's 500 ohm, it is usually stamped into the back case of a mic.
Dec 19, 2012 | Cobra 19dx Iv Eu Multiband Am Fm Cb Radio...
External mic for ft 50 yaesu purchase
Yaesu offers the MH-34B4B Speaker Mic or the MH-37A4B Earphone Mic for the FT50 HT.
Speaker Mic (Heavy / Standard Duty)
Earphone Mic (Light Duty)
Any ham radio store should be able to obtain these - if they are still in production / stock by Yaesu. Ham Radio Outlet aka "HRO" has stores nationwide and can ship direct.
I hope this helps!
Jan 26, 2012 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Break Channel...... Hey I just wanted to ask, how do I turn up the modulation on my RCI 2995 DX Ham radio? I am not talking about the mic gain. Inside the radio. Thanks in advance!!
For ham use which that DX model is for. the FM is preset and cannot be changed with adjustments. SSB andAM can be changed. But from factory should be good settings for amateur use.
Dec 16, 2009 | Radio Communications
Motorola Talkabout SX600R Handheld Two-Way Radio Logo
113 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
