Question about Dell 962 Photo All-In-One InkJet Printer
Dell AIO 962 copy & fax issues
I have a Dell 962 all in one with two major problems, both very recent in its 2 year history of acceptable performance:
1. Copies are not readable due to black lines and gray areas
2. When used as a stand alone fax it transmits pages of solid black.
The printer and scanner functions work fine.
I have recently changed the printer cartridges, cleaned the large scanner glass and the thin glass lens below the automatic document feeder. I am sure that the original is oriented with the correct side up when sending the faxes.
I have been unable to find any references to this combination of problems.
I have a 2 year old Dell Inspiron computer with Windows XP Pro, and am subscribed to Bell South fast access (now AT&T)
Any suggestions or references toward a solution would be greatly appreciated.
Thanks,
kellyplus
  • twentyways Nov 27, 2007
    scanned images come out with blotchy patches like the lamp on the scanner bed is leaving heat images on the outputted image
I'm betting the Cold cathode fluorescent lamp needs to be changed
Posted on Feb 22, 2008
My exact same pinter sends the black pages too. I can make it stop by turning on and off, but the problem is my receipent gets 30 black pages before I know. No idea what causes it, just a quick fix . It is to the point I turn off the printer and back on beofre I do any faxes unless it is directly for PC
Posted on Jan 16, 2008
    Problem Solver:
  • 13 Answers
Go to Dell AIO and click on maintenace/ Troubleshoot on top of the page. Then go to maintain or fix quality problems.
Then choose the problem and run it.
Posted on Dec 27, 2007
Aio dell 962 all in one cartridge error code 1203
Hi there
Please try this see if it may work.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Mar 07, 2010 | Dell 962 Photo All-In-One InkJet Printer
My Del 962 will not scan. The light does not come on and it does nothing. What should I do?
Hi,.... I'm having the same problem as sharon_mi334. My Dell AIO 962 does not copy, fax or scan...but prints. When attempted(copy, fax or scan), the output is a scanned image or a print out that's completely black. When I looked at the "scanner light unit/ copier camera" or what-ever it's called ... the gizmo that moves across under the glass plate,... I noticed there was NO light coming out of it as it should on any other copier, etc. Sooo,... is that the problem, ie: unable to copy the image? If so, can I fix that by replacing a bulb or a particular unit? Looking for some advice and thank you for your help and time.
medflight.
Dec 11, 2009 | Dell 962 Photo All-In-One InkJet Printer
I have a similiar problem with my Dell AIO Printer 962
reinstall the printer and fax cd that came with your computer
Jul 10, 2009 | Dell 962 Photo All-In-One InkJet Printer
PDell Photo AIO Printer 962 stopped working after windows update
I had the same issue after downloading the Dell AIO 962 printer update. What worked was using the uninstall mode on the original Dell CD that came with the printer followed by a fresh install from the aforementioned CD. Be sure to uninstall all copies of the drivers before doing the new install. Good Luck!
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell AIO 962 can't get a dial tone
There are 2 phone jack ports on the back of the 962.
One for line, one for phone.
You want to plug the phone line into the port that says "line" or "Fax".
If it's plugged into the wrong one, your fax machine will not get a dial tone.
Jul 31, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell AIO 962 Photo printer
hmmm..interesting..sometimes, in the translation from one fax machine to another, the grey scale densities don't match up. So, your printer almost certainly has a higher resolution than a standard fax machine. Only way to do this is to test and attempt to balance it from one machine to another. Maybe you'll get lucky, and they will be compatible.
got backup?
Feb 18, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell AIO 962 Scanner/Fax problems
Go to dell AIO and try the maintenance/ Troubleshoot.
Dec 17, 2007 | Dell 962 Photo All-In-One InkJet Printer
My Dell AIO 962 Printer does not respond
The printer is dead and needs replacement. If covered under warranty, u can get a replacement from Dell. Speak to Dell support and they can give you alternative solution.
Nov 08, 2007 | Dell 962 Photo All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
425 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
