Question about Traulsen RDT332NUT-FHS Reach In Refrigerator Freezer Combo - Self Cont
My traulsen refrigerator is warm not cold
I set the temperature control to number 6 and the still the refrgerato temp is still at 52 degrees after 8 hours of running time
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 61 Answers
The pump unit is burn
or you have a leakage on the cooling fluid !!
all your dealer and ask the sometime the answer those question with no charge $$ !
Posted on Apr 05, 2015
    Director Badge:
    Uploaded 100 video answers.
  • Traulsen Master
  • 488 Answers
Fixing freon leak on true air
Posted on Jul 18, 2015
Traulsen freezer with intella true continuously frosting the evaporator coil and blocking the air flow?
Your defrost circuit ... should (about twice each day) gently warm up.. and remove the frost to an evaporation tray at the bottom of your FREEZER (refrigerator?)...
Regardless of the design...
THERE are only two reasons for excessive FROST.
- massive air intrusion (check seals & gaskets)
- defective defrost circuit (check defrost timer/controller)...
EZ trouble to fix...
Post comment reply: 7/3/2016...
In general... there are only three elements to the defrost circuit:
- 1st failure is usually the "timer" (in your case (other cases it is being replaced by the power control board (do remove power: line voltages present).
- 2nd failure (inside ... usually atop the evaporator) is the "DEFROST THERMOSTAT" (designed the keep the heating element from getting much hotter than 55 degrees Fahrenheit, ("failing" = open.. prevents the heater element from being energized at all).
- 3rd the heating element... itself goes open (usually below the evaporator (caution: line voltages on 2nd & 3rd)).
Anytime you don't feel you've got this surrounded just comment me back... I'll be around.
Go to Bing homepage
http://www.bing.com/search?q=traulsen+freezer+wiring+diagrams&qs=AS&pq=traulsen+freezer&sk=LS1AS5&sc=8-16&sp=7&cvid=47349AEC29CA4E1D8902F3954D86C0BF&FORM=QBRE&ghc=1
Jul 02, 2016 | Traulsen Freezers
How do I fix the temperature on my Traulsen Model G22010 freezer: it is at 14 degrees and I want it to be 0 degrees
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/TR35924%20Owners%20Manual%20Quick%20Guide.pdf. Check out page 2 to see if these instructions will help with resetting the control.
Dec 24, 2015 | Traulsen Freezers
Traulsen G sereis 2 door freezer keeps running past set temp of "0" degrees keeps freezing all the way to -35 degrees and I have to shut it off to keep it from running? any advice??
It basically sounds like the temp sensor is not sensing the box temp that the control functions on. Other wise, the control may be stuck. Traulsen seems to have a fairly descent tech support line. Call them for steps on how to read the controller.
Feb 04, 2014 | Traulsen G-Series G22000 Solid Door...
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
Traulsen commercial freezer temperature cannot be set
Don't set hi and low. Set the "Set point" number. That is what it functions on.
Feb 25, 2013 | Traulsen Reach in Freezer - G22010
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
I have a Frigidaire model GLFU206FWA upright freezer. The temperature control won't go above 10 degree F. This causes freezer burn on some foods after a period of time. Is there a way to regulate the...
Good day,
Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F.
Otherwise people could accidentally set the temp too warm and cause a loss of food.
Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
Jun 21, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Red light is on on bottom panel and buzzer is going off. Inside temp is 20 degrees and outside temp is 25 deg
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Not all refrigerators are insulated the same and not all condensers are in the same place. Your cold control is monitoring the temperature of the refrigerator section and is designed to turn off the compressor to keep things from freezing in that section. If it stays cold long enough outside in your garage the cold control thinks its cold enough and won't turn the compressor on. A makeshift closet to hold a little heat the unit generates will probably help.
Jan 06, 2010 | Freezers
How do turn the temp up on a norlake walkin?
They are usually mounted on the front panel of the evaporator or mounted on the wall behind the evaporator.There is a possibility that the temp. control is at the condenser,and the sensing bulb was slipped thru the wall.Look for the bulb at the back of the evaporator and follow the cap tube.
Dec 05, 2007 | Nor-Lake Freezer Norlake Refrigeration 6'...
Traulsen RDT332NUT-FHS Reach In Refrigerator Freezer Combo - Self Cont Logo
206 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
