Question about RCA L32HD31 32 in. LCD HDTV
What might be the problem with tv making popping noise when turned on
Today both times the tv was turned on there was a loud popping noise. 1st time tv was turned on using tivo remote an the 2nd time was turned on at the tv. why doing this? is something like fire going to happen?
  • Dixie Makedonski Apr 05, 2015
    would this be inside where i can't fix or something that can be fixed or not any problem just a noise?
    Top Expert:
  • RCA Master
  • 75,571 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 05, 2015
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 61 Answers
You must have a wire ( sound plug ) not connect properly ,
sometime those plug loose with time ,
when powered the make connection and those sound happen !
BOUGHT JVC AV-56WP74 IN JUNE 2004. 52
It is worth getting an estimate. From the symptom you explained, it looks like the horizontal output transistor became defective.
Jan 16, 2010 | JVC AV-56WP74 56" Rear Projection...
Loud buzzing noise which became a very loud screech over the last week. Turning tv off and on seemed to remedy it. Today screen was only black and white, now no video only audio. Is this the picture...
This TV uses a lamp and color wheel. the color wheel is likely the problem since it is known to make noise over time and will eventually sieze. The repair is in the $400 range.
Sep 27, 2009 | GE 46GW945 46" Rear Projection Television
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
RCA HDTV DLP 50'' TV Goes Blank!!!
The bulb went out, The clicking is the ballast trying to start the bulb
Jul 12, 2009 | Televison & Video
My W3201C 32" LCD TV made a loud popping noise when I turned it off. Now it will not turn on. No power. No LED light.
That would be your transformer popping and dieing. Usually the popping is followed by a burning smell which is a good indicator that the part is unrecoverable. The cost of the part is variable based on the make and model TV and is usually not too labor intensive to replace. If not under warranty, let the repair gut know that you know what the problem is. Then, ask them to quote the cost of the replacement part and part number. Then ask them to quote you their hourly rate and get a time estimate. Then, google the part number and see if the cost is reasonable.
May 02, 2009 | Televison & Video
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
52 inch won't come on
did the loud noises come from the speaker or from the back of tv?
Dec 12, 2008 | RCA HD52W58 52" TV
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Snap Snap Pop
Probable bad IHVT ( aka flyback transformer ) part # 257805
or Asti 2078...................................T.
Nov 09, 2007 | RCA F32450 32" TV
RCA L32HD31 32 in. LCD HDTV Logo
144 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
