Question about Miscellaneous
I have a 65 in Philips rear projection t.v. the power will click on but the bulbs in the back won't come on what could be the problem
    Top Expert:
  • Miscellaneous Master
  • 52,135 Answers
Burnt out bulbs
Posted on Apr 20, 2015
4 Suggested Answers
  • 731 Answers
SOURCE: model # 51PW9363/17F can i
It appears this is a Magnavox unit. Many maufacturers use other and just put their brand on it.
Anyway the only hit i got was for a Magnavox 51PW9363/17F.
With some luck Sears may have your part:
Crt p16ltg00bmb(u) blue
Part for MAGNAVOX, Model # 51PW936317F
Number: 932217323682 Category: Home Electronics (Audio/Video
Call them (800) 252-1698
for availabilty
Posted on Apr 05, 2011
  • 3 Answers
SOURCE: tv will not turn on
need a model number to help you.
Posted on Apr 11, 2011
OATES_JASON
  • 39 Answers
SOURCE: Philips rear projection 720p I was told its probably the bulb, are those the bulbs and if so, how do I check if they are individually working or not???
whats the problem is there no power??
Posted on Nov 16, 2012
Power interuption to house temp. power came back but tv won't
The real question if model number indicated here is correct is does the green power light on the set come on at all ?
Aug 29, 2012 | Mitsubishi WS-65513 65" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Set won't come on blinks 5x fst then 6x slow
same problem on mine, i ask a tech. and that is 6x slow and 5x fast, error code 65, bad bulb! i took my bulb out and tested with a meter and sure enough its bad!
Sep 15, 2011 | Philips 50PL9200D Projection Televisions
Sony kp-65w5510 rear projection tv power button malfuction
Replace bulb and clean cooling fans of dust is the first thing to do. if that doesnt work might start checking capacitors on the power supply.
May 10, 2010 | Sony KP-65WS510 65" Rear Projection...
My kp-65ws500 rear projection 65' tv has sound but no picture... i opened the back and the bulbs dont turn on.
your tv is protecting itself ( please be very carefull becouse you are dealing with very high voltage aprox. 28000 or more volts its deadly my advise is to take it to your service center
Dec 16, 2009 | Sony KP-65WS500 65" Rear Projection...
I put a new bulb in.I had turned power off like directions asked.When done the power was turned back on but unit will not start up ??
would it power up before? if so make sure your bulb is seated properly if it did'nt then your ballst is most likely your problem you will need a tech to help you out
Nov 23, 2009 | Sharp 65DR650 65" Rear Projection...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
How do I get to the bulbs to clean them? I have a 65 inch flat screen rear projection tv which I purchased brand new about 8 years ago.
Unplug the TV.Remove the back cover.Gently wipe the three guns and the white screen.Reasssmble.By the way vacuum the chassis while you there
Oct 18, 2009 | Philips Magnavox 51MP392H Rear Projection...
How do I replace the lamp in my 65' sony rear projection TV
Sony KDP-65WS550 is rear projection TV that has 3 picture tubes inside. Let me know what bulb you are asking for help?
It is not DLP TV that has ballast Lamp for back light.
Jul 13, 2009 | Sony KP-65WS500 65" Rear Projection...
Miscellaneous Logo
70 people viewed this question
Top Miscellaneous Experts
Joey Gammon
joe bombardier
Level 1 Expert
Doug Davis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
