I had Print Shop 10 installed on Vista.After a hard drive replacement, I cannot reinstall it. I need to retrieve my files.The clean install I used before is not working. Any suggestions?
    Top Expert:
  • Computers & ... Master
  • 12,962 Answers
If you have the old hard drive , hook it up to your computer as a secondary unit and boot up with your new replacement. Then using windows explorer access the secondary drive, retrieve the files you want and either transfer them to an external usb stick or create a directory on your new drive and transfer them there until you can get a fresh copy of your program installed on new drive.
Posted on Apr 05, 2015
I had The Print Shop Signature Greetings before but it won't install on Windows 10. My PC says this program would not install on your PC.
First, you may have to accept that the older program you have to install may never work with Windows 10. The newer security fixes and updated features of Windows 10 may mean that older programs literally cannot run on modern operating systems.
HOWEVER, you may be able to install and run your program if you experiment with the program compatibility settings in Windows 10.
With your install CD in the drive, open Windows Explorer so you can see the files on your hard drive. Now select the drive letter for your CD/DVD drive to view the files on that disc. You should see a file called 'setup' or 'install' which would be the program executed to install your software. Right click on that file, and your should see a "Troubleshoot compatibility" option. Select that and then try to set the program to use settings from a previous version of Windows, like Windows 7, or Windows Vista, or Windows XP. Once you've select the version you want to try, click OK, then double-click on the file you just configured to cause it to execute. Hopefully, you'll get it installed. Good luck!
Sep 19, 2017 | Signature Computers & Internet
How do I erase hard drive
Right click the drive in Windows Explorer and choose Format
(Don't choose quick format)
Jan 15, 2017 | Hard Computers & Internet
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
May 14, 2011 | Encore The Print Shop 23 Deluxe Full...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Convert to raid 1 after Vista install
Install at least 2 more hard-drives, and configure them to use RAID.
Then, copy/move all your data-files from "My Documents" onto the new drive-set. The point here is to have "backup" for your files, not for the Operating System files (which can be re-installed from CD/DVD).
Your "programs" can stay on the "current" disk-drive.
Sep 10, 2009 | Intel DP45SG Motherboard
I brought a toshiba from the pawn shop and i tried to change from windows xp to windows vista how can i find a hard drive disk to install windows vista
You don't need to replace the Hard drive in the laptop, you can usually upgrade, or install vista from the CD-ROM / DVD-Rom.
If your laptop does not have a DVD drive to install vista, you may use file sharing to install it from another computer on the network. To do this follow these steps:
1) Place the Vista DVD in second computer
2) right-click on the DVD-drive that has the Vista DVD in it, and select " Share..."
3) You may need to press the "Advanced sharing" button to enable sharing, if so, do that, and just hit the " apply " button
4) OK out of all of those menues
5) on your laptop open " my computer" and click the " map network drive "
6) browse to the location of your drive on the other computer, and click " OK "
7) install Windows vista
If you do however need a new hard drive for your laptop, you can usually get them from any PC store such as Bestbuy, fry's, or online from places such as NewEGG.com, and Tigerdirect.com.
You will need to know what type of hard drive you have, and how to replace it. The manual for your laptop usually has this type of information.
SIDE NOTE:
When putting Vista on a laptop, be sure it meets the minimum requirements.
May 30, 2009 | Toshiba Satellite® A75-S276 (PSA70U005004)...
My Acer m5100 Vista won't boot =(
Successfully Reinstalling Vista would prove it's not the hard drive and just file corruption, although file corruption can be caused by faulty memory.
Jan 02, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
Drive C, full
Save all your files, your disk is risking to collapse at any time.
You cannot efficently run Vista on a 10 GB hard disk.
Minim efficient size it will be 40 GB or so.
Delete as many useless files as you can, use the hard drive cleaning tool that you find under all programs/accessories/system tools.
To save your file you can use the backup option in control panel, and save all files to an external USB stick or external hard drive or, do not use CD RW because the disk is full and there will be no space for disk image on hard drive.
If you want to keep using Vista I suggest replacing the hard drive for a bigger one.
Sep 05, 2008 | Computers & Internet
Toshiba satellite A205-S5847
well i had the same error on my toshiba...i spent literally 56 sleppless hours on the problem after giving up on the last 48 hour stint about 3 weeks ago...i installed a freash copy of xp...then used gparted live cd (linux small distro for partitioning hdds)to make a 10 gig partition in ntfs format....then i searched tiny vista and downloaded the torrent....that error is another way of saying you have messed up your bootmgr for vista..and it could have been a ton of things that did ruined it but none the less...after the torrent was downloaded (i know its not a legal copy but i used it just to fix my bootmgr) it has something to do with the way it sets up vista premium on your hard drive that fixes the boot problem.....and befor anyone says theres other ways to do it.....this is for extreme cases were you cannot afford a new hard drive and cannot get your factory install cd's to fix the problem ..... this is worth a shot in any case. .....forgot to mention that i used my windows xp partition to firstly download dvd decrypter and a copy of tiny vista (for you that dont know tiny vista fits on a 700mb cd and is remastered to install on its own with no help from you what so ever...then when i suggest deleting it from your hard drive and installing your own vista copy because after all all you needed to do was fix the boot... again..this is the only thing that worked for me other than buying a new hard drive i tried 30 different things and i garuntee i have heard it all..it was by accident that i found out this would fix the problem with oem instalations
Jun 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
