Question about Samsung WF419AA Front Load Washer / Dryer
Washer won't turn on at all. Circuit breaker in the house is fine and outlet works
    Problem Solver:
  • 9 Answers
Please see the Fuse of your machine, and if it is broken then replace it. that the common problem, if the machine wont turn on..
Posted on Apr 05, 2015
If there is no power for either the washer or dryer, is there an internal fuse or reset button
I assume you checked the circuit breaker for this outlet? Both appliances are plugged into the same outlet? I would try unplugging both appliances then attempt to reset the breaker again....throw it completely to the OFF position, wait 10 seconds and throw it to the ON position. At this point we are assuming the breaker is working. It could actually be defective. It could be tested with a meter or test light. If you don't have that try plugging a lamp or another device into the outlet the appliances where plugged into. If it works you know your breaker, wiring, and outlet work. If not you need to troubleshoot that...perhaps a ground fault breaker somewhere in between? If the outlet works with the test lamp, next plug in one appliance at a time to try to determine which pops your breaker.
Feb 06, 2015 | Dryers
Clarke power washers 150
Need more info:
What fuse? the one at the end of the cord on the pressure washer? Or the circuit breaker on your house?
If it is the one on the cord it may have gone bad. To test replace it with normal plug (non-GFI) and plug it into an outdoor or bathroom GFCI (GFI) outlet. If it still trips that outlet then there is a ground fault in the device which may be minor or major.
If it is a home circuit breaker remember that electric pressure washers use a lot of power - typically 1500 watts. If anything else is plugged in it can trip the house circuit breaker.
Jun 04, 2014 | Garden
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Circuit breaker is fine but still no power on one bedroom. PG&E said it might be a bad plug/outlet.
Turn off the circuit breaker and locate the plugs that are on that circuit. There is a good chance that the problem is between the closest working and faulty outlet. Starting with what appears to be the last working outlet on the circuit, check that all the wires are secure in all the fixtures and outlets.
If that does not fix the problem, a varmint may have chewed through a wire inside the wall. If you do not have experience with home wiring, you should get an electrician.
Feb 26, 2013 | Electrical Supplies
Where is the reset button. Our washer won't go on. It has no power at all.Tried the circuit breaker..Machine was here when we bought the house
Thanks for choosing FixYa Karen and welcome. You can unplug the washer for 30 minutes and plug it back up to reset the washer. Make sure the outlet works. Next, check your power cord. Wigglle it while plugged in to see if the power comes on. Inspect the cord first for damage before you do that. If the outlet, breaker, and cord is good, you need to check the fuse to the washer. If it still has no power, you may have a bad control board. Due to the fact there is no power, it is probably electrical. Inspect all wires in the washer for damage. You may need a voltage meter to test for power in the cicuits.
Aug 28, 2011 | Washing Machines
Maytag Neptune will not start.
""The circuit breaker is okay."" that is a good 1st check.
""I may have burnt out the wall outlet. "" Plug a 120VAC device to the washer outlet and see if it works. Why do you think you burnt out/damaged the outlet?
""Turned it off for a while and will try again later."" When you power up the washer do you have any Console indications that the machine is on. I will assume your machine is a FAV6800A TL. Do you have any LED display indicators turned on?
That is all I can help with for now. I'm a technical owner of the FAV6800A machine and will try t help if uour machine is a FAV6800A or FAV9800A.
Most important what is the model number of your machine. This forum fails big time to ask members for Model# and Serial # of their machine.
Here is the Service Manual for the FAV6800A/FAV9800A
Rich
May 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
We're attempting to label circuit breakers in our home. One is currently labeled "WM" and it's not the washing machine. What might it be?
Hello
It could have been the washer at one time but the breakers got moved around over time. The washer should be on its own 20amp circuit. What size is the breaker? 20amp? 15amp? It is on the tip of the switch of the breaker. If it's a 20amp it should be for the kitchen or dining room outlets. It could also be for an air conditioner in the window. If it's a 15amp then it could be for lighting or other outlets other than the kitchen, dining room or ac outlet for window ac. That's just the basics. How old is the house? I've seen some really mixed up wiring in older houses. You could also buy a "Sperry" circiut breaker finder for about $50. It has a outlet plug that connects to an outlet and another handheld scanner that you scan the breakers with to find the correct breaker so that you can label it.
John
Aug 01, 2009 | LG WM-1832C Front Load Washer
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
No electricity in all bathroom outlets
you may have agfi outlet in the circuit. the outlet has 2 push buttons in the middle. it maybe an outside outlet that is tripped some contractors hook up the circiut like that
Mar 09, 2009 | Siemens Electrical Supplies
Samsung WF419AA Front Load Washer / Dryer Logo
122 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
