My washer won't turn on - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check fuse in plug
Posted on Apr 12, 2015
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Door light turns on when you start the machine but turns off a couple of seconds after that and the washer won't do anything. It's a frigidaire aft7000eg0. Any ideas.
check the door interlock sensor. Somewhere there is a tab or button that lets the washer know when the door is closed. If this switch isn't being triggered it could be that the machine thinks the door is open and won't function.
Jun 01, 2011 | Washing Machines
My washer turn on but won,t spin
tub bearings may be frozen up. Can you move tub by hand?
Jul 20, 2009 | GE WPGT9360EPL Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
