Question about Saws
How do I connect the spring on the guard of this saw?
    Top Expert:
  • Saws Master
  • 42,991 Answers
I use a pair of forceps to hold the end and reattach to the little hook hole not an easy task by any means
Posted on Apr 05, 2015
  • Bob Adams
    Bob Adams Apr 11, 2015
    I could not find a pair of forceps small enough to reattach the hook to the hole. Really no room to move.
  • ray gallant Apr 11, 2015
    I got my small ones from a fly fishing store BASSPRO.COM
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 183 Answers
Remove any covers so the "hook" ends are exposed. A good zip tie will hold onto the ends of the springs while you work and a pair of skinny nose lock plyers to hold the working end while you pull-simply cut off the zip ties when you're done.
B & D #3051 worm drive saw: How do I access the return spring for blade guard?
Link,
Usually you will have to remove the blade guard to get access to that. There is usually a rubber stop with a screw going through it that you will have to remove, and a spiral spring clip on the inside of the hub of the blade guard that will also have to be removed and then you should be able to lift the blade guard off the saw. The spring will hook around the blade guard and the other end will hook to the saw housing. Hope this helps!
Apr 22, 2015 | Saws
How do I fix my spring loaded lower blade guard on my circular saw
I need to know the make and model of your saw in order to help you.
Jan 05, 2015 | Saws
How to replace a makita circular saw guard
Simple, unpug tool. Remove blade and back flange. Remove circlip and lift off guard. Unclip spring. Re-fit new guard. Refit spring and circlip. Refit blade.
Aug 18, 2013 | Makita Saws
Makita
I don't have this particular model in my shop right now but almost all circular saws work like this. From the blade side of the saw, the spring attaches to a hole in the blade guard usually around the two to three o'clock position. With the blade guard correctly positioned on the saw, wrap the spring clockwise around the bottom of the hub and back up the nine o'clock side. There is another hole or tab inside the top of the upper blade guard somewhere around the twelve to two o'clock position. Hook the end of the spring there and test the guard for free movement throughout it's range of motion.
Aug 06, 2012 | Makita Bare-Tool BSS610Z 18-Volt LXT...
SPRING LOCATION FOR BLADE GUARD
go to a store that sells the one you have and look at a new one . some wrap almost around the guard and some don't
May 01, 2010 | Makita 18V LXT Circular Saw
Replacing the blade guard spring
there is a hold in the lower guard for the loop and the other end wraps around the guard slightly and there is a hole in the back of the upper guard. You can go to Milwaukeetool.com and download a breakdown for the tool Also when you have the blade off I would try using compressed air to clean the area and spray some lubricant on the hub to lubricate. The guard should "snap" back when done sawing. Let me know if you need more help
Mar 24, 2010 | Milwaukee 6378 Saw Circ 8 1/4 15A Worm
Repair spring to lower guard to spring back on dewalt 18v dc390 saw
You may be able to salvage the torsion spring that is there. Sometimes the end will break off and you can bend yourself a new end and just stick it back into the retaining hole in the housing or guard. There may be damage to the guard which will not allow you to just bend the spring to make a new joint. Either way, you need to know what you are dealing with. First remove the blade if you haven't done so already. Then remove the bumper (rubber piece) that stops the guard from returning too far. Next you will need a pick or a small flat head screwdriver. Look around the hub and you will notice a retaining ring. You will have to use the pick or screwdriver to get the ring started. Look for a little tab around the perimeter of the hub. You will have to work that tab out and make sure you keep your pick or screwdriver under it. Then work it around and off the hub. Then you can remove the guard from the hub. The spring is located under the guard and is a torsion spring. Look for damage to the guard and the housing as well as the spring. If there is any question to the integrity of the guard you should replace it. The part number for the torsion spring is 612517-00 ($1.50), the retaining ring is 150383-00 ($1.50) just in case you break it, and the guard number is 611925-00 ($6). If you have any questions please post back.
Oct 28, 2009 | Dewalt DC390K 18v Cordless Circular Saw...
The spring for the blade cover has come off how do you fix it? my dad has given me his saw to fix the spring that brings the blade safety cover around, how do you fix it the the mounting post. When I do...
if it a Makita saw it will rub on the guard slightly, What is the model number or you can go to Makitatools.com and type in your model number to see a breakdown for this tool. The post is on the back side of the upper guard and there is a hole in the guard itself for the other end.
Oct 03, 2009 | Makita Saws
I am missing the part that brings the guard back when you lower the saw blade
I am assuming that you have some type circular saw?
Most popular saws use a spring to return the guard,with the saw unplugged raise the guard and see if the spring is there(you may need to take off the blade) if it is not there,replace with proper spring.one end of the spring will hook onto the fixed 1/2 of the guard the other to the front of the moving guard(consult manual if possible).once this is done insure that the guard mover freely and is not in the way of the blade.Replace the blade in proper direction check guard again for proper travel,make sure everything has been re-tightened .
If the spring is there check for material build-up or debris that is causing
guard not to move,remove blade clean debris or obstruction,replace blade and check for proper operation.Also visually inspect where the moving guard is attached to the saw for any unusual marks or wear this could be a sign that some type of unsafe situation exists,if this happens refer to a pro to fix or buy new never use a saw without a properly working guard,it took 141 stitches to repair my friends leg.
Sep 28, 2009 | Hand Tools
Power Glide Circular Saw with Laser Guard Spring Broken
The spring hooks onto the blade guard and wraps around the hub of the blade guard. It is orta hard to see but it will hook onto the guard.
Feb 11, 2009 | Ace Hardware Power Glide Circular Saw with...
Saws Logo
175 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
