Question about Horizon Exercise & Fitness
No power. Plug good. Wall power good no lights
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 188 Answers
Internal fuse or breaker has tripped. Call your local repairman.
Posted on Apr 05, 2015
Unit will not turn on, used 1 month last year. reset button on end of cord. green light goes on, when i reset, green light goes off. when i plug into wall it kicks out reset button again.
Hi, I think the first step is to obtain a user manual for the unit, and quickly...if the documentation does not reveal what is wrong then you should take advantage of warranty service...you need to find out if something is wrong and if it is get back to the supplier within warranty
If you have no documentation please provide details of make and model
Jul 08, 2015 | Heating & Cooling
Electricity problem - wall socket power
The circuit breaker, ground-fault protector, or surge protector has tripped off, but many of them let small amount of current through anyway, which is enough to light the low power neon or LED indicator.
Jul 07, 2015 | Televison & Video
No power at all. No lights. just dead
Try plug it into a wall outlet that you know is good. If that's not the problem turn the power switch to on, then test the power cord plug for continuity, if none the power is not getting to the unit, could be the switch is bad, or wire broken/disconnected inside unit.
Mar 07, 2015 | Vacuums
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
My dell laptop dont turn on
Is there a green light on your power supply that plugs in the wall? If not, the power supply is dead or there's a problem on the motherboard.
To troubleshoot, unplug the laptop from the power supply, unplug the power supply from the wall. Now, plug the power supply into the wall, you should see a green or blue light. If there's a plastic spot for the light but no light is coming on, replace the power supply - better to try a known working on before spending the money on a new replacement first.
If there is a light, plug it into the laptop. If the light goes out when you plug it in, there could be a motherboard problem and the board needs to be replaced or the power jack is damaged and you need a professional to replace it.
If the light is on the whole time, but laptop does not turn on, this could also mean that the board is still bad.
Regardless if it doesn't power up with a good power supply it is usually a motherboard problem and the board needs to be replaced.
Check with dell to see if its under warranty and they will send the parts needed and a tech to replace if it is. You can also ask about purchasing a warranty so your money is better spent to keep your laptop alive and put it towards something useful for the lngevity of the system instead of just paying for the part and a tech.
Feb 11, 2011 | Dell Studio 1737 Laptop
Was using the laptop (dv6426us) and it just cut off. Was plugged into outlet with power supply, no warning messages prior to that. Now it will not power on at all, no lights, no beeps, nothing. If I unplug...
First, measure the voltage coming out of the power supply. If it is good (specs will be on the power brick itself.) then this sounds like a short on the motherboard. To eliminate all else, remove anything that is removable (hard drive, CD/DVD and RAM). Leave the battery out also. Plug in the power supply and see if it beeps. If not, you have a bad motherboard. If it does beep, replace the ram. At that point, you should be able to see POST. If you get nothing, it is the ram. Keep adding until the problem resurfaces. The last item added is the culprit.
Good luck.
Aug 12, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Dell Inspiron 1721 - screen goes black
check the light on the power supply that you are hooked up to. before you plug it into the laptop see if there is a green light when the plug has power from the wall. if you see a green light on...good. it means the power supply is responding correctly so far. if you get no green light, then your transformer is out in the psu. if you get a green light and plug in to the laptop and the light goes out, one of two things could be going on. first there could be a short in the psu like the previous tech said, the second more serious issue could be the power controller on the motherboard. they've been known to go out. like the tech before said. try another power supply if you can. but if you are getting a green light on the power supply before you plug it in...there may be another problem with it.
good luck!
Ruben
Jul 18, 2009 | Dell Inspiron 1525 Laptop
No Power
Usually there is no fuse in the printer itself. The big block that you plug into the wall is actually a transformer. It converts the 120V power from the wall outlet to a much lower voltage and also converts it to DC power.take the plug in end with the cube transformer in it and bring under a good light and it will read the specifications about that power converter. What sometimes happens is that the transformer inside that cube fails (through various causes) and thus produces no voltage or the wrong voltage. Take the plug with you to an electronics store of your choice and they will direct you to a universal 120AC to a DC transformer (it will have various settings and various plug adapters) and then follow the instructions to match the voltage on the old power converter. I hope this helps you out.
Jun 04, 2009 | HP Photosmart 3210 Printer
HP PHOTOSMART 475 WILL NOT SWITCH ON WHEN PLUGED IN
hmmm...ok..unplug from computer first
then with power switch/button depressed, AND power cable out of wall, plug it into the wall, hold button for 30 seconds..
if that's not ok, then make certain the light on your power input is good. We're assuming the power is good from outlet, right?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | HP Office Equipment & Supplies
Exercise & Fitness Logo
207 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
