Question about Tablets & eReaders
Lines and flickering while browsing on tablet
  • Zia soofi
    Zia soofi Apr 06, 2015
    how to stream from tablet Asus Koof Memopad 102a to TV?
My asus screen keeps flickering
I would open the back cover with a flat metal opening tool like this: http://www.ebay.com/itm/Tech-Metal-Spudger-Opening-Tool-for-ASUS-Nexus-7-1st-2nd-Gen-ME370T-ME571K-NEW-/161561753109?ssPageName=STRK:MESE:IT
then disconnect the battery 1st before anything. Check the LCD cable which is silver and runs from the MB to the LCD top to bottom over the battery. It looks kind of like a stick of gum. They often become loose and just need to be reconnected and secured better with some electrical tape. Be careful with the clips. I'm almost certain that is where your problem is and you should be able to fix it without much trouble.
Good luck
Apr 20, 2016 | ASUS MeMO Pad 10 ME102A-A1-GR 10.1" 16 GB...
My new Samsung SM-T310 tablet screen flickers so much I cannot use it. is there a fix?
find out if the actual display or just the back lights are flickering first .
turn on a good flashlight lay it on the face of the display when lights go out if the picture remains then it is the back lights not the display
but either way i believe you will end up replacing the display (backlights included( and probably LEDs) ) i will look at availability and feasability of this, come back with item model number and year
Jan 12, 2015 | Samsung Galaxy TabPRO SM-T320 16 GB Tablet...
How do you delete cookies onthe toshiba thrive tablet
Cookies and Browsing history may be deleted using the Privacy Settings in the Android Operating System. Simply click on the Settings icon, then go to Privacy Settings. On the right you will be able to clear cookies, cache and browsing history.
Oct 20, 2014 | Toshiba Thrive 101Inch 32 GB Android...
How do you delete cookies onthe toshiba tthrive tablet
Oct 20, 2014 | Toshiba Thrive Android Tablet
Screen display on iPad 2 changed to blue background with slight flickering. This happened while using - it did not drop. Reset has not solved problem.
Turn it over on your lap or on something soft like couch or carpet. Karate it chop it on the apple logo. Start softly and keep using more force. Folks have even used a hammer to do this but I don't advise it. You can also drop it face down on carpeted floor. Your ipad is likely stunned and needs to be stunned again to return to normal.
Mar 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I have a motorola xoom MZ604, i dont know how to activate to browse, i want to know if it can browse internet using its micro USB
You must be on Mobile Data or Wifi to browse the internet. The MZ604 is wifi only so being connected to Wifi is only way.
Feb 23, 2014 | Motorola Mobility Xoom Mz604 Tablet Pc...
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
