Cant get hot water into my washing machine'hoses and filters arn't blocked
  • Washing Mach... Master
  • 5,323 Answers
2 THINGS TO CHECK UR WATER INLET VALVE AND UR WATER TEMPERATURE SWITCH? USE A METER AND CHECK FOR CONTINUITY ohms, try switching the hoses on inlet valve and see what happens
Posted on Apr 16, 2015
Kenmore top load washer. The hot water intake hose delivers twice as much water as the cold water hose. Can the cold water flow be adjusted to match the hot water
probably the washer in the tap is failing and blocking the flow to the hose or the filter in the end of the hose is blocked
Jun 10, 2016 | Kenmore Washing Machines
How do I unblock filter of washing machine
Turn of hot tap and disconnect hot water hose from inlet solenoid, using long nose pliers pull out filter from solenoid.
The problem may well be the solenoid needs replacing as they do tend to fail occasionally.
Oct 10, 2014 | Fisher and Paykel GWL11 Top Load Washer
Error code f 11
f11 is no hot fill assuming its a hotpoint that meens you are not getting any hot water gonig into the machine moor likly to be a fault with the hot water valve or kink in the hot pipe or filter in the hose blocked where the hose is connected to the washer valve
Dec 01, 2011 | Washing Machines
Model LAT8504AAE Hot water pressure has been reducing over time, little by little. It is now only cold water. All house supply line valves are open.
screen in hot water fill hose is probably stopped up.turn water off unscrew hose at both ends check for a screen,if not in hose check at water inlet on washer pop out screen clean under kitchen spayer and reinstall make sure you put hose washers back in the hose ends that should fix your problem!!!
Jun 12, 2011 | Maytag Washing Machines
Hi. Have an Electrolux EWF 1229 that has stand still for some time. Vhen I started it today I got an error with code E 20. My manual is gone so I hope you can help me regards Arne
The waste outlet is blocked.
Open up the filter at the base and clean that out (you will need to catch the water).
It could be the drain hose out the back has kink it it.
Remember there will be a load of water in system so you will have to catch it !!
Feb 05, 2011 | Washing Machines
No hot water for wash cycle
Hot fill valve shot or blocked
Take supply hose off the back and check the filter is not blocked
If it is clear check that it is taking in water by running the machine with no background noise in the room.
While the machine is supposed to be filling switch the power off and listen for water dripping into tub.
No noise , no fill , new valve required
Jan 03, 2010 | Whirlpool Washing Machines
When my Duet washer is not running, it slowly fills with water. This has happened about 3 times.
the most common problem with a slow filling washing machine is a blocked filter
this is located inside the hose usually near the machine.
it this is not blocked
it may be a stuck valve, to test if this is the case connect the hot water and see if that fills quicker.
a short term fix would be to connect both hoses to cold if you can.
If your machine requires hot water to function it may not fill all the way because it will switch off if there is no hot water.
hope this helps.
Apr 21, 2009 | Whirlpool GHW9400 Duet Washer
Cant find the filter
check your hoses first. they have sediment filters in them, then check your water inlet valve, that is where the hoses hook to you machine.
Feb 06, 2009 | Whirlpool Washing Machines
Cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
Aug 20, 2006 | Hoover Nextra HNT 2135 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
