Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
Error code e 91 for frigadare affinity dryer
It is beeping and has error code e91
  • 822 Answers
Most likely faulty control board...........
cheers
Posted on Apr 05, 2015
What does it mean when my Frigidaire professional series dishwasher has an error code of 91 and the China/Crystal setting light is illuminated?
Rod, Try unplugging or turning off breaker for ten minutes to reset. If this does not fix, you may want a good Tech. have a look, diagnose and estimate repair.
Code E91 could be User Interface to Main Control Board communication error. Communication problem. Check the wiring between the Main Control Board and the User Interface Board. Wiring bad, correct wiring problem. Wiring good, replace the User Interface Board. If the problem is not corrected, replace the Main Control Board.
What Is Error Code 91 On Frigidaire Dishwasher Professional Series
http://www.manualsonline.com/support/frigidaire/dishwasher/error-code-91-5195801
http://forum.appliancepartspros.com/washer-repair/476079-error-code-91-a.html
http://www.elektro-ivicic.cz/data/user-content/soubory%20ke%20stazeni/Electrolux-chyby.pdf
Jul 14, 2016 | Frigidaire Dishwashers
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
How to get the error code test on Frigidaire affinity model FARE1011MW
Good Afternoon Friend,
I understand you are receiving an error code on your Frigidaire dryer, model# FARE1011MW. I see that when you press the start button, your dryer beeps and the drying light begins flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Dryers
I have an error code 64 on my dryer. I am out of work doing chemo right now. can anyone tell me what the problem is
If your Frigidaire Affinity dryer is beeping at you and giving you the "E64 CALL SERVICE" business, chances are you have a bad heating element. The good news is, with a screwdriver, a pair of pliers (a multimeter if you have one) and a new heater element you can fix this yourself and save a couple hundred bucks.
Below I outline a step by step process to do this on the Frigidaire Affinity, but this guide may help with other dryers, as they basically all function the same way.
A WORD OF CAUTION: You will be handling a lot of thin sheet metal components. Be careful as it is easy to cut yourself on them.
First you'll want to unplug the dryer. Then disconnect the vent hose and the water feed (if applicable). Be sure and shut off the water valve first, or you'll have a mess!
http://therandomfix.blogspot.com/2013/07/frigidaire-affinity-e64-error.html
Apr 03, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
Frigidaire affinity front load washer, my power went out and came back on, now the washer keeps beeping 3 beeps about every 30 seconds. Error code E91 will flash up when I push any button
Hi bsful1 - Typically, E91 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
Apr 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire affinity error code 68
what is the name and model of these dryer.rate these for clean solution
thanks
Jan 16, 2013 | Dryers
E91
Hello - Typically error code E91 on Frigidaire washer indicates a communication error with the user interface to main control board. A certified technician will need to check the wiring between both parts. Either part could be defective or unit may possibly have faulty wiring. Depending on the diagnostic either or will need replacing.
Nov 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
Prndl switch problem error code e91 and ee 91.92 cadillac deville
the switch on top of the transmission where the shift cable is . it probly is not anny good. check all wiring . make sure thair is no dirt inside the connector
Jun 08, 2009 | 1996 Cadillac DeVille
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
214 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
