Question about Jandy Aqualink Rs4 One Touch Control System Control System
I have a Jandy Aqualink pool system. When I turn on the spa and heater, the spa drains..I've never had this happen but don't use the spa much. What should I check?
I'm not getting any error codes, but the spa drains when I turn it to spa and heat
  • David Spradling
    David Spradling Nov 22, 2017
    also check cable see if cut
  • 60 Answers
His is not typically a control panel issue but more likely a valve issue.
Your valves are set as follows wih a few minor variations.....
Pool mode- sucks from pool skimmer and or pool vac line and returns water to both the pool and spa.
Spa mode - self contains the spa , meaning water is sucked from the spa and returned only to the spa.
If your spa is draining then most likely one of your electronic valves is failing...most likely it's the return valve so what is happening is the water is sucked from the spa and returned to the pool instead of self containing the spa.
Easy check is to be next to the equip when spa mode is selected and two valves should move and align properly, the return side valve is most likely not moving or it is not moving into the correct position.
The fix is either adjusting the valve acuator or buying a new valve acuator.
Another thing to check is on the main panel circuit board to ensure the return and auction 3 pin plug ins are still connected.
Posted on Apr 05, 2015
    Top Expert:
  • Jandy Master
  • 6,498 Answers
See if the actuators are plugged in to in and out if on solar make sure to re assign jvas also check in set up make sure no programs or heater isn't activated with jvas
Posted on Jun 21, 2016
  • Jandy Master
  • 1,631 Answers
I would agree with pool guy. If you put your automation system into spa mode, switching from pool mode, if it was a suction valve not turning, then your spa would overfill.
my guess is the return valve actuator, not turning. It is staying in pool return but the suction valve actuator turned. So water is now sucking from spa and being sent from the spa, and returning to the pool. In time = empty spa.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 57 Answers
One of your valve actuators is stuck or the switch is off. Itll be the valve actuator on the suction side. Look at the main filter pump, then follow the pipe going into the front of it to that actuator. Theres usually a switch on it, the switch may be in the off position, if it is in one of the on positions then you either have a bad actuator, a bad actuator wire, or a bad spot on the board.
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
PartsCenter
  • 125 Answers
SOURCE: Have a Jandy aqualink clorinator.
link to the Trouble Shooting Guide
Posted on Mar 04, 2009
  • 128 Answers
Disconnect the spa side remote.
Posted on Aug 23, 2009
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
Jandy Aquilink control panel keeps tripping circuit breaker
turn off heater if it still happens mark all auxs remove all then try again if it doesnt blow fuse plug 1 in at a time until it does thats whrer your problem is
Aug 16, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Why does spa drain when I turn it on?
check the JVAs are turn to the correct positions
Nov 10, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink RS
Jul 11, 2009 | Jandy AquaLink RS2/6 All Button Dual...
Feb 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
My aqualink says heater off line
What kind of heater? Is it a Jandy? Onb the digital board, there is a rubber button that needs set to pool or spa. It will say RS offline if this is the case.
Dec 11, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
460 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
