Question about Oster Health & Beauty
Can't get my oster 8131 to come apart for cleaning
How do I take apart razor to lubricate the motor?
Oster Classic 76 hair clipper - take apart to clean or fix ...
? 9:53
https://www.youtube.com/watch?v=nu8UaoCxtxo
Feb 20, 2010 - Uploaded by darwincollins
It is an amateur video demonstrating how to take apart a Classic 76 clipper. ... your clipper with Oster Kool Lube 3 Clipper BladeCoolant Lubricant Cleaner. .... Motor did not slide out but all wires shredded and motor was in pieces ... What's that little button just below the '76' for and how do you know exactly ...
MOTOR TEST Checking the motor on broken Hair clippers ...
? 0:32
https://www.youtube.com/watch?v=TaWUxcdGBSg
Mar 29, 2015 - Uploaded by You can Fix It!!!!
Testing motor on shears clipper trimmer razor shaver. How doyou know if the blades or motor are brok... ... oils oiling oileddisassemble disassembling take apart taking apart .... 3:21. How To ' Change Cord ' Change Switch ' How To Repair Wahl Clippers ' - Duration: 2:24. by ronsclassickuts 13,453 views.
How to sharpen a Norelco electric shaver - Instructables
www.instructables.com/.../How-to-sharpen-a-Norelco-electri...
InstructablesYou will need a small brush to clean shaver and heads, also a flat piece of ... I then take a tool I made from a broken Norelco razor and a writing pen which ... Mix a 1;3solution of White toothpaste [1] and Mineral Oil [3] on the back of a ... Disassemble[keep the screens & blades mated] and spray with Bathroom Cleaner. 5.
Taking Care the Right Way to Keep Electric Razor Like New
Dec 06, 2015 | Health & Beauty
Can't get my oster 3181 to come apart for cleaning
Hi Mary, if it is not an Oster Shaver or Clipper then it may pay to ask again in the correct category, it seems it may be a juicer.
Apr 05, 2015 | Oster Health & Beauty
How to assemble an Oster 3125 can opener?
Hello, Here is the users manual that you are looking for: Oster 3125 User Manual
May 25, 2014 | Oster 3125 Tall Can Opener, White
Instructions oster power pro cordless clipper
go google and see if there is a workshop or user manual for the clippers
Jun 26, 2017 | Health & Beauty
My blender base has become discoloured with a sort of green mouldy streaks, how do i clean
If you remove the blinder base where the blades are you can put it all in the dishwasher. To do this grab the handle on the pitcher then unscrew the plastic base from the glass. make sure that you look how it comes apart first. then put in the dishwasher to clean. Then reassemble the way you took apart.
Jan 11, 2011 | Oster 12-Speed Brushed Nickel Blender...
The driver that operates the kneading blade ( paddle) is falling out of the baking pan from the bottom. It appears a washer has disintegrated. Pieces seemed to fall apart when cleaning. any suggestions? I...
There is a sealed bearing at the bottom of the pan. This allows the paddle to rotate. The bearing has failed and is falling apart. This usually happens with age or use. Time for a new bread pan. If you are lucky you can find one on ebay. Sorry for the bad news....Hank
Dec 09, 2009 | Oster 5838 ExpressBake Bread Maker
Oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Jul 14, 2008 | Oster 76076-040 Hair Trimmer
Oster Kitchen Center won't hold a steady speed
My wifes Oster Kitchen Center slowed down and I think finally stopped. I say I think it did because I took it apart two years ago and am finally finding the time to get it back together. I cleaned it, checked the brushes on the motor(all of this is in the base unit with the control buttons on it. The upper blender/beater arm has no electrics in it.) The brushes were coated with some kind of dried crusty stuff which was keeping them from contacting the motor.I put it back together and tried it but it only hummed and did not move.
I took it apart again, this time everything came out. Motor, electric wiring plus the metal gearbox attached to the motor which drives the blender and the upper arm. I took the transmission apart (it's attached to the motor in the base unit) and found the gears in it were so gummed up with who knows what. Probably everything that leaked out of the blender.
You see, what happens is that the seal between the blender black base and the glass jar started to leak after a few years but we don't notice it. Maybe we did but we cleaned it and we thought it was all good. But the liquid can leak down into the bottom unit around the drive teeth and that little square drive that the blender locks onto. And then it goes into the gearbox and the motor. So it is a major job to clean it. Since I don't have a manual for disassembling the lower base unit, I'm just putting it back together. I cleaned all the gunk out, put some grease on the gears and the gearbox is working better but I fear not perfect. It is 30 years old!! So unless you take it apart yourself or find an appliance repair shop (is there such a place anymore?) it might not be worth the effort. But it is do-able. How long have you got?
Mar 01, 2008 | Food Mixers
Motor haveing a hard time turning
try hitting them when thay are runing with your hand on the sid and bottom see what happens somtimes the brass bearing gets out of alinment or it can be the bushing on ether end.you can call me at 813-310-6211 jaime i rebuild them thats florida time.
Feb 17, 2008 | Oster 76076-010 Hair Trimmer
Health & Beauty Logo
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
