Question about Fitbit Charge HR Heart Rate and Activity Tracker Sleep Wristband Large
The display has gone dead, the button does not work and it is charged
My fitbit seems to have died on my wrist. It is totally unresponsive. It has never been in water, never worn in the shower. It just died..
My fitbit flex died - cannot wake it up; also it's tied to my cell phone and that doesn't respond - totally blank!
How to fix broken Fitbit - sync Fitbit with phone app - PC ...
www.pcadvisor.co.uk/how.../how-fix-broken-fitbit-sync-image-3499292...
May 15, 2015 - Fitbit Flex, Fitbit One, Fitbit Zip, Fitbit Force or Ultra not syncing with the Fitbit app ... To get the Fitbit app sync working again restart the Fitbit tracker. ... charger, has a battery charge but is not lighting up, or isn't tracking your steps. .... I've already done all the obvious stuff: turning off my phone, turning off and ...
Fitbit Flex review - The disappointment we've all been ...
blog.hyperexpert.com/fitbit-flex-review-the-disappointment-weve-all-be...
May 5, 2013 - My wife and I are both in good shape, we both wanted the Flex just to ... app, wait for the device to finish connecting and syncing to your phone, ... to sleep mode, I have to do all of this? and then again to wake it up? .... Also, doesn't the manual say "not" to wear it in the shower? ..... I appreciate any response.
Jan 06, 2016 | Fitbit Flex Wireless Activity & Sleep...
How does fitbit work?
you wear it on your wrist after you charge it up via the usb charger.
You download fitbit app on your phone and then add fit bit to phone .
I am not sure how it works I am guessing it has a motion detector in it and each step causes a vibration it detects.
It must have some sort of a pulse sensor as it also knows when you are a sleep .
you need to set up an account using an email address with fitbit via the app.
there is also a windows app but you need the fit bit dongle that comes in the box it came with plugged into the usb port of p.c.
even thoug pc has bluetooth it does not seem to work with the p.c application unless the dongle is used with it.
Dec 31, 2015 | Fitbit Flex Wireless Activity & Sleep...
When I press the button the only thing that will display is the time and then it turns back off. How do I correct this.
Make sure your Fitbit is fully charged by plugging it into its charger, it should vibrate and you want to see a fully white battery indicator when pressing the button.
While it is on its charger let's do a reset, by holding there button until you see the Fitbit logo.
Jun 01, 2015 | Fitbit Charge Wireless Activity Tracker...
My Charge Fitbit is not holding a charge. Yesterday it was dead within 1.5 hours. I have used the paperclip to try to reset without success. I am ready to throw in the towel so to speak.
You can put the software right, with a reset. Hardware errors and batteries won't change a bit when you use the reset button. When the battery is bad, and it looks that way, just return the Fitbit and ask for a new or new battery. It still should be under warranty. If the warranty is only 90 days for the battery, never again buy a Fitbit in the place you are living. In Europe electronics have a warranty of 24 months.
Apr 19, 2015 | Fitbit Charge Wireless Activity Tracker...
Neato seems to have died but the green light is on
Mine was doing same thing. was working flipped upside down to replace the rubber blades then nothing.Display dark only it has green led around orange button. Unplugging batteries didn't help.pressing buttons nothing. holding buttons down nothing. Found this on another site. Connect the vac to your computer and place it on charger at same time. Press and hold the orange button for about 10 sec. or so. it should turn of the LED then let up and repress button. vac should then reboot. Unplug computer. Wouldn't hurt at this time to tell it you put in "New Batteries" but first remove any scheduled cleaning days to clear its memory. After doing the New battery, reset the schedule and let it charge. After that it maybe a good time to check your program version and update it from the Neato web site to the newest update. The newest update does wonders for the battery run time issues.
Feb 07, 2014 | Neato XV11 Vacuum
Xpera arc totally dead after charging
mostly it seems like a software problem. Did you try restarting it by pressing VOLUME DOWN + POWER button??
if it's not working , then take it to a service center and re-flash the software once.
Nov 06, 2013 | Sony Ericsson Xperia LT15i Arc X12...
Fitbit 4.14 flashing
This happened to my Fitbit, but it occurred because of putting it through the washing machine and the dryer. When I first took it off the shirt it was on, I couldn't get a response of any kind from the device no matter how long I held the button or put it on the docking base. I followed the Fitbit site instructions to put it in a cup of rice overnight. The next morning, I pressed the button and got nothing. Then I put it on the docking base and it flashed "Fitbit 4.14." Everywhere I looked online said this meant the device was damaged and would need replacement. My husband suggested I try to reset it while it was on the base, so I held the button down until, to our surprise, the battery symbol came up, which meant it was low on charge and was no charging. I let it charge for awhile, took it off the base, pressed the button, and amazingly I got my normal display and it rotated through all the options just as it should. There's no guarantee that this will work on every device, but try all of that before you give up. It just might work.
May 05, 2012 | Fitbit Facebook Apps
Fitbit Charge HR Heart Rate and Activity Tracker Sleep Wristband Large Logo
109 people viewed this question
Top Fitbit Exercise & Fitness Experts
L Pfaff
L Pfaff
ray gallant
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
