Question about Smeg Kitchen Ranges
Our smeg range has no power. Have checked switch and mains. They seem okay. What could be the cause of the power loss
4 Suggested Answers
  • 209 Answers
SOURCE: smoke from oven
I am a recently retired appliance engineer of 20 years sounds like pure coincidence, check the fan for circuit at terminals, and / or check for movement of blades, that you have not got fan jammed, replace fan motor unit if needed, still cheaper than a call out if i have helped rate me work with safety all the time, unplug at all times when working on any item
Posted on Sep 09, 2007
SOURCE: Smeg DUC08CSS Main oven not functioning
reset automatic clock
Posted on Mar 15, 2008
  • 409 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
Hi i have inherited a Smeg range cooker when I
Unfortunately, I don't have a solution for you. That's because I have exactly the same problem. Did you ever discover how to fix this problem?
Jul 14, 2010 | Ovens
Oven not coming on/heating up although top plates are working
If the burners are heating up but seem to take along time to get up to heat and your oven doesn't seem to be working you may have only 115 volts of power going to the range rather than the full 240 volts that are needed to power up the bake/broil oven elements.Check circuit breaker(s),check range receptacle behind the range for 240 volts,check for full power at the terminal block on the back of the range where the cord connects to the range.Good luck!
Nov 22, 2009 | Smeg Ovens
Smeg SUK91MFX5 oven overheating
REMOVE BACK PANEL TURN OFF POWER CHECK WIRING TO & FROM CORD BLOCK
Oct 19, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
I have a Smeg A1 Oven which has lost it's power
The fuse is located behind the rear panel of the cooker. Depending what model this is, it may be an electronic card causing the problem?
Apr 02, 2009 | Smeg A1A.1 Gas Kitchen Range
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smoke from oven
Sep 09, 2007 | Kitchen Ranges
Oven doesn't heat up
two possible causes first, element is breaking down when hot. one way to check is to put a multi-meter across element and see if it stays powered up. second, stat is faulty. check if element power cycles with stat
Jun 17, 2007 | Smeg A1A.1 Gas Kitchen Range
Electric oven fan
This problem is caused by one of two components, depending on the model, there is a thermal cut in thermostat that keeps the fan running until the unit has cooled down and on some models there is a four wire timing device that keeps the fan running for a specific time after the temperature drops, the fault can only be casued by one of these components. Smeg Service Engineer
Aug 21, 2006 | Smeg A1A.1 Gas Kitchen Range
Kitchen Ranges Logo
54 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
