If I have the volume real low I can hear it but once raise the volume there is now sound but still on. Mics light blinking.
SOURCE: Subwoofer crakling sound when playing anything.
there are 2 possibalites
1) sound system does might not be supporting the volume that you want
2) The speaker coil might have become weak so it might be making cracking sound
Posted on Dec 18, 2007
SOURCE: FLM 3232 television low volume
I hooked my tv up and there is no sound coming from the tv. I do not have surround sound just the tv. How do I make it work I need volume please
Posted on Jan 15, 2008
SOURCE: hear sound but cant get any real volume even at full blast
I was playing around with my Sherwood RD 6513 and adjust the the output level to its maximum, amongst other settings. This limited my output on the amp to a maximum volume of 65 not 90+.. Anyway i pluged in the microphone and done another 'auto setup' of the volume levels and distances, and this allowed the volume to exceed 65 again!
Also if you have an external source such as a DVD player - i would assume you have already checked its output volume setting?
Posted on Mar 08, 2009
SOURCE: People cannot hear my voice very well (volume is too low) when I am speaking.
On the side of the phone there are two arrows, one stands for plus volume, the other stands for Minus volume... Try It!!!
Posted on May 24, 2009
  • 70 Answers
SOURCE: the volume on my Acer Aspire D250 es too low
Some songs are recorded with a low volume... Try to get the last audio driver. If not, get some large headphones :)
Have you ever had louder volume?
Posted on Nov 29, 2009
I have a 2001 chrysler voyager installed a kenwood stereo and when i raise the volume to where its lound the radio will turn off and on untill i lower the vol
My electronics savvy source says you may be overdriving the amplifier in your Kenwood stereo to an impedance-mismatched set of speakers, meaning that the speakers are impedance mis-matched to the Kenwood stereo, and therefore operate ok (but inefficiently) at low volume, but cut off completely at higher volume.
Fix: match the impedance of your speaker network to the specs on your Kenwood car stereo. Once this is done, you should be able to crank up the volume to the point of permanent hearing loss.
SAFETY CAUTION - sound levels above 85 decibels produce NIHL (noise-induced hearing loss).
http://www.dangerousdecibels.org/education/information-center/faq/
Oct 18, 2011 | Kenwood Car Audio & Video
We have a Magnavox TV model 20MS3442/17 bought in 2004. Without touching the remote control, the volume will lower very low and eventually raise back. If, when the volume is low, we raise the volume to...
1. Find the 5 & 12 or 9 v line caps. Try to replace electrolitic caps.
2.Find out the keypad pin from the processor and suck it. Then use only remote.
Oct 24, 2017 | Philips Magnavox 20MS3442 20" TV
Hello I can hardly hear on all of my channels. I have directv and I can't get a reasonable volume. Is there something I can do to fix this problem?
Directv low volume problem.
One sure way to eliminate Directv's low volume and any other volume problems in general is by installing a stereo compressor between your Directv receivers audio outputs and your TV's audio inputs. (Simply plug the compressor's outputs into TV and your receiver outputs into the compressor's inputs). By correctly setting the controls on the compressor, you won't loose the dynamic program content. Not only will it raise the volume level to where you want it be, it will also prevent it from exceeding any set level you chose, actually limiting how loud any sound can be. These settings are fully adjustable. In other words when you switch from Directv back to a dvd or any source, no more sound blasting, you can set levels to be the same now since you have raised then adjusted Directv's level to normal. Plus a compressor will raise those low hard to hear audio sections often found in movies. This is the reason we used them all the time in the recording industry. Another benefit is it levels all channels on Directv. The result, channels are now the same volume. This is what I'm doing to end the problem. Hope this helps someone. J Pynckel
Jul 27, 2010 | Directv H21 DTV Receiver
My microphone won't work. I can't hear my voice.Toshiba Satellite
Check which microphone device u have set up. Try changing it around. Also try just speaking closer to the microphone and into the mic. Some mics just are not good.
Aug 04, 2009 | Toshiba Satellite P105-S6104 Notebook
Micro not working...
I honestly think that we dont weven have a mic, I have the same Nettop and i see the little mic simbol but when i attempt to use it, it does not work. I always have to use my headset to record sound on it.
All mics on aspire ones are defective, heck, there are some people that say even their externa; mics dont work
Aug 01, 2009 | Acer Computer AOA150 Notebook
The volume is very low even at the top of bar
Look for a speaker icon in the taskbar (near the clock in the bottom right of the screen). Click it once and raise the slider.
Apr 25, 2009 | Dell Inspiron XPS M140 Notebook
My Dell's speaakerss are REALLY soft, i can BARLEY HEAR! How do i make 'em louder?
The master Windows volume control is set very low. In Control Panel, Sound Devices, raise the slider bar for "Master Volume".
gurutim
Mar 21, 2009 | Dell 5650 Computer Speakers
Altec lansing ada 745
need to check your control center,then if thats not the one"it should be set @ 3/4 volume....
if no diff,,,,,then you need to go over checking every program that shares it,,,has their own volume control,,,somewhere there is the problem,,,maybe real player,,,media player,,,flash player etc...
thnks ttyl
Polywoggy1@hotmail.com..
Mar 10, 2008 | Altec Lansing Multimedia Computer Speakers
Handset microphone volume low
Uniden 900MHz cordless phone can hear ringing. When I pick up the phone, volume is very low, hardly hear other side. Volume controls do nothing to raise it.
My email: xiejj01@yahoo.com.au
Nov 05, 2007 | Uniden Cordless Phone
164 people viewed this question
 Grubhead
Grubhead
