Question about Cuisinart Food Mixers
Cuisinart stand mixer stopped working between mixes. Can hear a click when you hit the on button. Lights and timer come on
ricardok45
  • 135 Answers
SOURCE: Stopped Mixing While Kneading Bread
Hi again Libby. You're right to be scared about further damage. If you want to fix this machine yourself, stop using the mixer. Go to the Kitchenaid website and download the drawings that match your mixer model Unplug the mixer! Take a screwdriver and remove the silver band from around the head of the unit ( 1 screw). Next remove the four screws that hold the top part of the mixer. Remove that cover, and look for a 'humpy" looking cover at the front of the machine. Examine this transmission cover carefully. If the cover is made of plastic, look for cracks. If you don't find cracks, you'be better off taking it to a repair shop. If you do find cracks in the plastic cover, remove the four screws that secure it. Remove the trans. cover.
You will now see a lot of grease in this exposed transmission. Put on some latex gloves, get a bunch of paper towels and move some of this grease aside so you can lift the worm gear assembly free of the mixer ( see Kitchenaid drawing). Wipe it off and look for damage to the worm (spiral) gear. Look for damage on the other gear of this assembly, inspect the 2 bronze bearings at either end of the shaft. You're looking for cracks in, or pieces missing from the bearings, look for damaged teeth on the gear. Should you find damage at any stage, that part must be replaced. These parts can be ordered from the Kitchenaid website, and will take about a month for them to arrive.
When you order the required parts, insist that the replacement trans. cover be made of metal. When my mixer "blew up", my replacement was a metal one. If your problem dosen't fit the above solution. I can't help you further. If it does, please rate my solution.
Depending how much grease you had to take out to do the inspection, you might have to order a container of grease to replace it. Good luck! ricardok45.
Posted on Jan 31, 2009
  • 143 Answers
SOURCE: Kitchenaid Household stand mixer. Model no.
it is hard to tell you exactly what it could be, but a common problem is after a while the transmission gasket does deteriorate and will begin to leak oil.the gasket is part number4162324. the rattling noise inside your unit is most likely cause by a chipped gear inside, this can happen when the unit is put under heavy loads, such as dough. this problem could get worse as there may be fragments inside that will damage it more.hope this helps
Thanks
Posted on Oct 11, 2009
yeroc
  • 397 Answers
SOURCE: hi i just had my mixer spark and then the motor
Could be carbon brushes, switch it's really hard to call it,
Let us know how we can help you
Posted on Nov 25, 2009
welcomejee
  • 10594 Answers
SOURCE: My Cuisinart stand mixer won't
It sounds Motor Control Board got problem as you hear relay click but motor does not get power to rotate from motor control board.
It is electronic hardware failure issue, its not user level repair and professional can do it.
Click Cuisinart Contact link to find out nearest repair center in your area.
Hope these info will help you.
Thanks.
Posted on Oct 09, 2010
woobie dog
  • 1273 Answers
SOURCE: i have a 600 watts
It sounds like you have a stripped gear. I, too, had this problem when my bride dropped a wooden spoon into the bowl. You'll need to disassemble the mixer and determine the part(s) that need to be replaced. With a google search for parts for your model, you can not only locate the exact part, but can also get exploded diagrams for your model. Very handy indeed for disassembly/reassembly. I'd get the diagrams first and then determine the parts needed.
Hope that this helps you.
Best regards, --W/D--
Posted on Jan 22, 2011
Attachments not turning. Small screw located next to accessory power port unscrewing when mixing.
Paula, Put a drop of loctite on screw and insert securely, let sit to dry 24 hours to cure.
press the helpful button and follow me on fixya for more tips and info.
Feb 14, 2016 | Cuisinart Cusinart 5.5-Quart Stand Mixer
How can i fix this problem
PDF]SM-70 INSTRUCTION BOOKLET 7.0 Quart Stand ... - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/sm-70.pdf
Cuisinart7. Do not exceed the maximum capacities listed in this use and care instruction book. 8. ... Troubleshooting . ... extra-large Cuisinart™ 7 Quart Stand Mixer.
Jul 30, 2015 | Cuisinart 7 Quart Stand Mixer
Cuisinart SM55 circuit board replacement or wiring chart.
I have a Cuisinart 5.5 quart stand mixer. but its count down model does't work. it move as fold model when I push on button. I guess the circuit board was broken. Is my guess right? Where can I buy the Cuisinart SM55 circuit board and how to replace it?
Jul 23, 2012 | Food Mixers
My cuisinart 5.5 stand mixer when you press the on button it starts for a second then it stops.
Make sure the plug is securely plugged into the wall.
Next, remove and reattach any mixing arms etc that may be attached to the mixer. Having one not attached properly can result in a start, start.
If problem persistes make sure the speed is reset.
If problem continues, here is an excerpt from the user manual found here.
http://www.cuisinart.com/share/pdf/manuals/sm-55.pdf
Problem: Your stand mixer has an
overload protection device and if
overloaded, it will shut down to protect
the motor.
Solution: In the unlikely even that this
happens:
• Turn off and unplug the unit.
• Reduce the load by removing some of
the ingredients, and allow the mixer to
stand for a few minutes.
Plug in and reset the speed. If the
stand mixer does not start when you
press the on button, allow the unit to
stand for additional time.
If you are still having trouble, the product comes with a 3 year limited warranty, so if you're bought it within the last 3 years it may be covered.
Good Luck!
Mar 01, 2011 | Cuisinart SM-55 Stand Mixer
HL 600 timer board I think
Sorry so late but the reason you need the kit is because the potentiometer (the knob that selects the time) is no longer part of the timer board.You need the pot,and board.I'm a hobart tech,if any other questions let me know.
Jan 05, 2009 | Hobart A200 Stand Mixer
Food Mixers Logo
75 people viewed this question
Top Cuisinart Food Mixers Experts
Ross Keen
john h
Are you a Cuisinart Food Mixer Expert? Answer questions, earn points and help others
