Question about Apple iPod classic MP3 Player
How do I remove the case on my ipod - Apple iPod classic MP3 Player
    Top Expert:
  • Apple Master
  • 10,875 Answers
Pry it off with guitar pics not metal utensils
Posted on Apr 05, 2015
How to unlock ipod
there are two options by which you can unblock the code on your ipod. Follow any of the procedures tomorrow.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Take care.
Jun 24, 2010 | Apple Premium Skin Case for iTouch 2nd...
I have ipod nano 8gb that got wet and want to fix it
I have fixed a few electronic devices (phones, jump drives, radios) by immediately removing the battery, removing screws and cracking the case open a little, and placing it on top of a lampshade with a 40 watt bulb. Device should be at least 8 or so inches away from the bulb. Keep it there for a couple of days in the warmth of the bulb. You might want to place a cloth over the lamp shade to keep a little more warmth in there.
You might not have any luck with the ipod because you can't remove the battery fast. It is very important to be able to remove all power from the device. It is also tricky to crack an ipod case open. This is needed to be able to dry effectively at all.
If it works after a couple of days of drying then that's great. (At least crack the case open.) It should work. But with an ipod, don't count on it. If it doesn't work, mount it on a placard as a reminder to check your pockets before laundry day!!
Nov 23, 2009 | Apple iPod nano
My audio output seems to be not working.. I wonder why, and if there's a way to fix this.. can you help me here?
If you have tested other head phones and already restored the iPod using itunes with no resolve; you will need to replace the jack. It's very cost effective and not hard to do either. I have posted a step by step on restoring as well as dismantling the unit to repair it yourself. You can purchase the necessary parts from several different places. However I found the cheapest site to be
www.ififxit.com
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
And if you need to replace anything here is a full description on removing the appropriate parts. The tools needed can also be purchased on that website for under 4 dollars. I do hope you find this helpful and easy to follow.
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
With the casing separated, grasp the top half (the part with the front bezel) and flip it over. Note that there is an orange cable in the top left corner that connects the iPodlogic board to the headphone ports. If you gently grasp the cable and pull, it will slide out of its connector on the headphone port module board.
Headphone Jack Board Removal Before proceeding, you must remove the top case.There are two t6 screws holding the headphone port in place. Remove both of these screws. You can now remove the headphone module.
Hard Drive Removal Before proceeding, you must remove the top case.Hold the hard drive up, and remove the black tape on the hard drive connector. This will reveal the hard drive cable’s connector to the logic board.To remove the hard drive, grasp the cable (thumb on top index finger onbottom) and gently pull the cable out (away from you and the connector)The hard drive will now be free of the iPod logic board.
Hard Drive Cable Removal Before proceeding, remove the hard drive.To remove the hard drive cable, hold the drive, and gently pull up on the cable.It should come out easily.
Headphone Connector Cable Removal Before proceeding, remove the hard drive.To remove the headphone connector cable, Grasp the cable, and gently pull up. It should come out easily.
Logic Board Removal Before proceeding, remove the hard drive and headphone connector cable First, disconnect the battery connector by grasping the cable and gently pulling up to disconnect the cable from the logic board connector. Remove the 6 black T6 Screws.
With the screws removed slightly move the logic board to the left to give more access to the clickwheel cable. Gently pull this cable to free it from the logic boardconnector.The logic board will now easily come free from the case. The LCD will still be attachedto the logic board.
LCD Removal Before proceeding, first remove:Hard DriveHeadphone Connector CableLogic BoardTo remove the LCD, grasp the green connector cable, and gently pull to free it from the logic board connector. It should come out easily.
Battery Removal Before proceeding, first remove:Hard DriveHeadphone Connector Cable Logic Board To remove the battery, use a flat tool to pry the battery up. It is held on with a lightadhesive, and should come up by using just a little force. Lift the battery out of the unit.
Each part that you can purchase comes with its own set of instructions as well. Just remember when reasembeling the unit that it takes very little pressure with the unit. Cheers:) Let me know how it goes as well. I always appreciate feed back.
May 12, 2009 | Apple iPod MA446LL/A MP3 Player
IPod won't turn on
If this is a new iPod, then take it back to the retailer. Your battery is no good. If it is used, there probably is not any kind of warranty. However if you want to replace the battery it is really easy. I have a web page that you can purchase a battery replacement kit as well as full detailed instructions. There is a video on the second web site listed. However i do suggest following the written instructions as leaving everything else connected can make it a hassle. :) If you have any other questions about this or difficulties with the resolution please do let me know.
iPodbatterydepot.com
www.fixyouripod.weebly.com
Simply do every thing in reverse to put the iPod back together. Make sure to remember that it only takes gentle pressure to remove and replace the parts.
May 10, 2009 | Apple iPod nano
Dead battery?
Battery is bad. If you use a dock most of the time, it is overcharging or never gets the chance to relearn its capacity. If it just shows low battery but will still work, just run it with a low battery until it shuts off. Then recharge it completely. Do this three times. If no improvement, you need to replace the battery.
Mar 29, 2009 | Apple iPod MA446LL/A MP3 Player
My ipod will only work while plugged into the docking station
If the part is stuck inside the iPod you can take the case apart quite easily and remove the broken part. If this is not the issue and I am way off please do let me know :)
Mar 28, 2009 | Apple iPod nano MP3 Player
Apple ipod click wheel not working.
You will need to replace your iPods battery. It's not as hard as apple would have you think either. :) To order a battery replacement kit you can go to:
www.ifixit.com
and to view a free video guide you can go to:
http://fixyouripod.weebly.com/
Also below I have posted a step by step on opening the case and removing each part. Once your inside the unit you will see that putting it all back together will be simple enough. It looks allot like a mini computer. :) Let me know if you need any further assistance with this issue. Also I do hope that it's not too late for a resolution to it. Cheers
Mar 23, 2009 | BoxWave Corporation Apple iPod mini (4GB)...
DEAD IPOD 8GB
You can disasemble the iPod to see if there is any visable water damage. If there is and you want to replace it, you can go to www.ifixit.com and order the appropriate parts there. Also at the bottom of this entry you will see another web address. This is where you can watch free iPod repair video's. :)
Mar 21, 2009 | Apple iPod touch
Ipod won't turn on
You may need a new hard drive for your iPod. Its allot easier to replace then you would think to :) If you go to the following web page there are a few video's on trouble shooting this kind of issue as well as instructions on taking apart the ipod and replacing a few of the items. Also below I have posted a step by step guide on completely disasembeling an iPod.
http://www.ifixit.com/
Mar 10, 2009 | Apple iPod nano
Ipod doest not work
Do you mean there is no power to the iPod when it is not connected? Or that you are not able to manually manage the music within the iPod using iTunes? If it will not power on without power behind it, you just need a new battery. you can view a free video on batter replacement at the following web address. also the second web page will take you to an iPod parts online store. And just in case you need the written directions I have posted them below :) Let me know if this is not the issue you are having, or if this does not resolve it.
http://www.ifixit.com/ ----------------------------------------------------------------------------------------------- Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
Mar 03, 2009 | Apple iPod nano
Apple iPod classic MP3 Player Logo
48 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
