Question about Garden
Gauge shows that it is getting power, but motor does not come on to pump it up.
Filled with gas, went 1km n flat spot and died,gauge show empty n could rev gauge showed full n same problem! Now car won't fire just turns over
Hello Steven,
Sounds like your fuel pump may have failed. With everything (radio, fans, etc.) off, turn your key to "on" (not start) position and listen for the fuel pump trying to prime the system. If you can't hear the fuel pump, then either the pump is bad, or you're no longer getting power to the pump so check fuses and relays.
Since you did not include vehicle details (year, make, model and engine size), we can only provide very general diagnosis.
Best regards,
Feb 11, 2018 | Cars & Trucks
Why won't the fuel gauge work?
The power wire from the sending unit runs to the gauge. Since it is showing 3/4 all the time. It is a break in the wire or really high resistance. I would check resistance of the ground wire first. If it is good(less than 5.0 ohms), I would replace the power wire from the pump to the gauge. I assume the gauge goes to empty with the key off. If not the gauge is bad.
Oct 05, 2016 | 1997 Chevrolet Blazer
Gas gauge staying at empty when tank is full
Spencer, Check all fuses ,plugs and grounding at the tank.The sending unit module, inside the GM's gas tanks were notorious for going bad in this err, when you changed it did you use a quality part? Also the fuel pump sending unit plug/wire harnesses were known issues, so much that replacement pumps would often come with replacement plug to splice into existing harness. Check the attached links,instruction and guides on how to trouble shoot fuel gauge/sending unit, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
General Motors Fuel Gauge Troubleshooting American Autowire
GM Defective Gas Gauge Leaves Owners Guessing
Fuel Gauge Tech How To Properly Diagnose Faulty Fuel Pump Sending Unit
GM Fuel Pump Level Sensor Diagnosis Testing
Aug 27, 2016 | 2000 Oldsmobile Alero
It is tripping motor starting on load and tripping
If the pump turns easily by hand and trips breaker, most likely the start capacitor is weak or bad. If the pump is hard to turn by hand then problem is most likely the in-tank check valve is leaking pressure back to the pump causing the motor to overload. If the pump turns easily by hand and the check valve is good and capacitors are good, then use amp gauge to verify overload, if amp gauge shows normal amp draw then most likely weak reset button. Good luck
Oct 29, 2015 | Air Tools & Compressors
Need wiring diagram with breakdown of colored wiring on fuel pump motor on 1999 mitsubishi galant ES, 4 cyl
the two thick wires are for the pump and the other two for the fuel gauge ,check for voltage at the pump if no voltage then follow the wires back to see if their is a connection somewhere ,also check the earth connection if no power in the two wires ,ie one probe onto the earth and the other to a suitable ground on the bodywork ,then continuety
Jan 17, 2015 | 1999 Mitsubishi Galant
No power to the fuel pump
Is there power to the fuel pump circuit of the relay? if so is it getting out the fuel pump side of the relay?
Oct 05, 2014 | Cars & Trucks
Put a manual gauge on my 1997 to read oil pressure, will get down to 10#, but not the zero it was showing on the dash gauge. what is the next option, new oil pump or perhaps a new electric gauge where the...
You can try a new oil pump, but in my 30 plus years 99 out of 100 your bearings are gone! you would have to pull the oil pan to do oil pump so i would pull 2 or3 main crank caps and check bearings if badly scrached or copper spots showing through aliumun coating there is your low oil press. probiem.you will need a new motor sorry. B. HARRIS A.S.E. cirtified
Apr 20, 2011 | 1997 Jeep Wrangler
I have a Jacuzzi laser sand filter. The system worked fine until I noticed that the circulating motor was extremely hot when running. The pump and motor were very old and in poor shape. So I replaced the...
this sounds like a supply power problem. The motor is not getting enough power. Check the line to see how many amps you're getting. The motor will tell you how many amps you need on the data plate. When a motor heats up and trips it's internal high limit, it's usually due to insufficient supply power. Heat is a byproduct of inefficiency. Also, if this is running on 220v, make sure both legs of 110 have power. Sometimes motors can attempt to run even though half the volts are missing.
Oct 30, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Fuel guage on my 2006 chevy trailblazer stopped working and now it doesn't work right it fluxuates even when the tank is all the way full
possible fuel gauge malfunction but its a chevy.
over the past year chevrolet fuel pump failure has increased by over 900% the fuel level sending unit is incorperated in the fuel pump module,
these fuel pumps do not like fuel additives nor do they tolerate E85 fuels.
you will need to replace your fuel pump assembly, try to locate a carter brand pump they are very reliable.
as far as replacement.
just open the fuel filler door remove the two torx screws and one push pin from the fuel filler neck, go under the truck at the back of the bed on the frame cross bar and unplug the bed plug, remove the 8 bolts that attatche the bed to the frame and the one ground wire under the bed by the fuel filler neck. get a budy and lift the bed off of the frame, now you can access the top of the fuel tank for the pump replacement. dont get discouraged it is a easy fix, i can do these in under an hour.
wesleyschacht@hotmail.com
Jun 14, 2009 | 2006 Chevrolet Trailblazer Ext
Garden Logo
235 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
