Question about Brother Se425 Computerized Embroidery & Sewing Machine
In lcd says to lower pressor foot so i do but wont turn on off button to sew green it stays red hel0
    Top Expert:
  • Brother Master
  • 44,414 Answers
Best I can do is this link to support Support Center
Posted on Apr 05, 2015
What adjustment can I make to my lower looper, thread does not stay under pressor foot while sewing
thread tension can be adjusted by the small screw that holds the spring plate on the bobbin carrier under which you have to pull the thread after the bobbin is placed in the carrier
a small movement is a lot of tension adjustment
if the thread is bunching up under the material ,that will be the needle thread tension and it needs to be tightened
Sep 28, 2015 | Sewing Machines
Bar that sewng foot is attached to for raising & lowering suddenly will not drop sweing foot all the way down to plate. Any suggestions on how to fix?
Perhaps you accidently moved the switch that enables free hand embroidery? It's up and under next to the pressor foot lever. Slides forward and backward. Forward the pressor foot will go all the way down to the feed dogs. Slid back and it keeps the foot up off the feed dogs but allows the thread tension to work properly. It would be easy to accidently move it when operating the pressor foot raise/lower lever.
Aug 31, 2014 | PfaFF Sewing Machines
Problem with striaght stitch pressor foot
it's possible that the needle bar is out of alignment and needs to be fixed at a sewing machine shop
Mar 18, 2014 | Kenmore Sewing Machines
Stop start button is not turning green when I put the foot down
Is the foot correctly attached? Is the machine clean? Bobbin winder on or off? Try turning it off again crisply.
Feb 25, 2014 | Juki Hzl-K85 Computerized Sewing Machine
I can't get the pressor foot on the silver part came off and the actual pressor foot
Place the foot under the arm while arm is in up position. Put arm in down position and foot should snap into place (line it up where it is supposed to go together before lowering the arm).
May 11, 2010 | Brother XR-65t Mechanical Sewing Machine
When I push the pressor foot down my machine flashes E1
Is the presser foot lever up or down? It should be down before you step on the foot controller or use the start/stop button.
For additional information, try this URL: http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/HomeSewingMachine/hf_cs6000btieus.html?reg=us&c=us&lang=en&prod=hf_cs6000btieus
Aug 24, 2009 | Brother CS6000i Computerized Sewing...
The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Apr 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
White d'lite 1750c presser foot in down position not recognized
I occasionally have the same problem with my White d'Lite 1750c. I turn the power off, let it rest a minute, then turn it on again, and the problem goes away for a long time (weeks, sometimes months). Of course, the settings go back to the default, so note your settings before turning the power off.
Hope this helps. Good luck!
Fran CW
Nov 17, 2008 | Sew D'Lite Lightweight Portable Mechanical...
Simplicity 4 thread EZLock 880 pressor foot settings
Easiest way to get the tensions right, use 4 different coloured threads
Make sure the tension disks are clean........run a length of fabric in a see saw fashion through each tension unit.
....set all the dials to 3 or 4 then sew test.......take a look at what needs attention, make a small adjustment and test/adjust until the needle threads are firm and the looper threads meet neatly at the edge of the fabric with just the absolutely tiniest hint of being loose.
Jul 16, 2008 | Sewing Machines
Pressor foot
Go to this link on the Brother website to order:
http://www.brother-usa.com/homesewing/modeldetail.aspx?PRODUCTID=LS2125&tab=optional
Jul 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother Se425 Computerized Embroidery & Sewing Machine Logo
32 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
