Question about Kenmore Kitchen Ranges
My pre-heat light want go off on my kenmore electric stove model 790.9419 after pushing start
    Top Expert:
  • Kenmore Master
  • 43,095 Answers
Sears might have the answer User Manual Downloads
Posted on Apr 05, 2015
SOURCE: Stove keeps shutting off by itself
HI I have a different brand, but this same thing was happening to our oven, I had to have a repairman replace the temperature sensor in the oven. Apparently it was reading the temperature as like 300 degrees higher than it actually was so it was shutting off (I guess as a safety mechanism). Hope this helps. Good luck.
Posted on Feb 12, 2007
SOURCE: Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Posted on Jan 02, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a kenmore stove 362.7361193 pilot not on
There isn't a pilot light on MOST modern gas ranges. The top burners are controlled by individual igniters through a common spark module. The oven, however, is controlled by an igniter on each manifold. One for bake, one for broil. If you are having problems with ONE of the oven features, I would suspect a bad igniter. If BOTH oven features are bad, you may have a bad Electronic Oven Control (EOC) board. If the oven works, but none of the surface burners are working, I would suspect a bad spark module. The following link explains a little theory on oven igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Since your range appears to have a common gas safety valve and regulator, all burners are fed fromthe same gas source. Which means, if you have ANY burners lighting, you probably don't have a gas problem.
I hope you can determine what your problem is from the information I provided. If not, please post back and elaborate a bit more on your symptoms so that I may assist you better. I hope this helps you.
Posted on Jul 22, 2009
  • 53 Answers
SOURCE: kenmore electric stove oven top element (broiler
the element is easy to change. just slide out the stove from the wall. take off the rear cover and just unplug or unscrew the leads from that element and replace. first make sure you unplug the stove it's self from the wall. it does have 220 volt and will hurt you.
Posted on Sep 05, 2009
SOURCE: Have a kenmore electric range that does not heat
I cannot no heat from the bake,convection,broil features.No codes show up and the computer seems to do its work.
Posted on Sep 27, 2009
Oven will not pre-heat properly
you might want to check where the thermometer is located on older models it can be knocked out of position perhaps to close to the roof of the oven which gives false heat reading
May 01, 2015 | Kenmore Kitchen Ranges
I have an electric kenmore model 362 oven/stove trouble.
Are you sure that there is not a buton on it that says degrees Celcuis of Farenheit. It happened to me a few years ago. If there is such a button try pushing it to see if it will go back to normal.
Feb 28, 2013 | Ovens
Pre-heat oven, insert food, after few minutes, stove shuts off - no heat.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 10, 2011 | Kenmore Ovens
I have an older model Kenmore with the oven and stove combined. The control panel for the range is touch button. Lately when I push the bake button the digital read out just flashes and the oven does not...
may want to try disconnecting electrical connection,or turn off breaker for a few.if problem does not go away,there may be more of a problem
Oct 10, 2009 | Kitchen Ranges
Kenmore gas stove not coming out of pre- heat model 66575842001
This sounds like a flame sensor problem. No signal from sensor will shut down gas valve. Check flame sensor position in flame/or replace
Sep 02, 2009 | Kitchen Ranges
Kenmore gas stove Model 790
It could be that the sensor wire that controls the main gas valve is out of position. It should sit in the pilot light flame.
Look, and adjust if needed.
If it's ok, then you need a replacement main gas safety valve.
This should only be fitted by qualified personnel.
They do give up eventually after years of heating, and fail safe.
Dec 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Stove won't heat
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kitchen Ranges Logo
62 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
